***? Yellow spots coming through base coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2010, 12:32 PM
anybody ever had this or seen this? yellowish spots coming out of the base paint, like its coming right through the blue, last year i had like 4 spots, but they dident come out for like 4 months after the car was repainted, but now a week later and one is coming out on the fender, not the same spot as last year, im stumped, got no idea what so ever
Old 05-24-2010, 01:08 PM
milo's Avatar
point on positive
why not post a picture ?
Old 05-24-2010, 01:42 PM
Underground's Avatar
Last journal entry: 54
What was done to the car BEFORE you painted it? Body work, primer? Did you seal the car before you painted?
Old 05-24-2010, 03:11 PM
yep, primed with high build primer, sanded then paint, dident put on any sealer, will try to get a pic in a bit
Old 05-24-2010, 06:47 PM
its not showing enough for the camera to pick up, but here is a pic of the car
Old 05-24-2010, 07:05 PM
Are those spots where you primered it?
Old 05-24-2010, 08:45 PM
TucsonJay's Avatar
Sounds like a problem I once had. Two questions....... did you use any lacquer on it? If you did, what kind of body filler or glazing putty was used?
If there isn't any lacquer, Don't bother to respond. It's not the same problem.
Old 05-26-2010, 06:17 AM
Old Fool's Avatar
without full details of the process from the git go no one will be able to help you as there are a dozen things that can go wrong and cause your problem.
Old 05-26-2010, 06:43 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
bondo bleed from red hardener.
Old 05-26-2010, 10:32 PM
Rag top bird's Avatar
Hot rods are still the king
I agree with shine i had the same problem on a white car it had that yellow ring where the repair work was done
Old 06-10-2010, 05:36 PM
and its getting worse, other fender is doing the same thing? How colud the blue paint seep past the high build primer and into the bondo? there is like 5 coats of high build over the bondo, its just dupli colour high build in the spray can, but that shouldent matter
Old 06-10-2010, 05:37 PM
a small dent, filled with bondo, with red hardner, sanded smooth, 5 coats of high build primer, gray, and blue base coat, thats about it
Old 06-10-2010, 06:04 PM
BarryK's Avatar
This use to be a big problem when base coats first came out and what caused it was a peroxide reaction in the bodyfiller, usually it would happen to people doing little spot repairs or warranty work where the bodyman would watch the filler dry, sand it right away and then slap some primer on it.
In other words the filler did not have time to gas off, so some of the shops took the primer step away from the bodyman and just the 30 minutes it took to get the car taped up and in the paint shop stopped a lot of this.
There were other factors, we also learned at that time and one was a certain UV inhibitor used (#1130 if I recall right) in the clear would aggravate the problem, Ciba made some changes to that UV and that helped, (some), also certain polyols (resins) used in the clears also contributed to the problem.
We have since lived and learned (oh it was costly!) and today, it is really not much of an issue.
HOWEVER, you overrode all that great change in technology and chose to use a spray can of primer, (lacquer), that sure can do it and to answer your question about it traveling through all the paint, it will sure do it.
If its bad enough at this point, even if you sanded and coated with epoxy, it can come back again.
Edit:
I should also add using to much hardener in the filler does not help either.
Old 06-10-2010, 07:01 PM
TucsonJay's Avatar
The problem I had was with Rage body filler. If I used any kind of lacquer product over it, it would release a stain from the body filler....sometimes months later!!! It got me on about 5-6 jobs!
I finally asked House Of Kolor's tech line, and they told me about that.
I stopped using Rage... switched to Fiberglass-Evercoat brand, and the problem was gone. It's the only time in 40+ years of painting that it happened.
Old 06-10-2010, 07:45 PM
thanks a million guys, I appreciate the help and info, So it looks like 800 dollars down the drain agian, plus I did all the labour myself, probally around 40 hours worth of work, I think the primer part is o.k, as it is pretty much on the entire car, like 4 cans, I guess its just where the bondo is under the primer, if this is the case, there will be alot more yellow spots than this on it very soon, also the bondo was like 5 days dry before primer went on
sanding base for clear coat holy85 Body - Exterior 1 08-14-2009 06:30 PM
Eliminate filler pinholes with dental pik and credit card cboy Body - Exterior 8 05-21-2009 05:48 AM
Base coat orange peel - what should I expect cboy Body - Exterior 9 11-22-2007 07:51 PM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
Help please-sanded through base coat fastblueheeler Body - Exterior 11 10-01-2003 07:32 PM
