Yet another 383 build up, questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2010, 05:16 AM
I have done some research and think I have the set up that should work, but because I am new at this, I want to get some feedback.
I am building a 79 camaro and this is the setup I came up with, bear in mind, I am in the planning phase so every can be subject to change, so alot of help, comments and suggestions are really appreciated.
I am planning on the following for the camaro:
TH350 Auto with 2500 stall
posi rear end with 3.73 gears
Rear wheels will be 17x9.5 with 285/40 tires
As far as the engine, I was thinking building up a 383 stroker with the following:
Eagle Internal balanced rotating kit (5.7" Rods with Hyper pistons)
Comp Cams XR282HR-10, (Comp said I will need a custom grind on a 1.050" base circle to clear rods, which they will do for no extra charge through them. Cam specs: Advertised Duration 282/288, Lift .510/.520, Duration at .050 inch Lift 230 int./236 exh. )
Going with Hydraulic rollers and 1.5 roller rockers.
Dart Pro 1 Aluminum Heads, (200cc intake runners, 64cc comustion chamber)
RPM dual pane intake
750 CFM Carb, unknown make yet, Holley or Edelbrock??
I think that covers most of the specs needed for some advice. Is there a specific carb that would work best with this application? The camaro is not a daily driver, it is going to be driven once or twice a week just around town. Maybe take it to the strip once or twice. My brother in law has a 90 something camaro with mild mods on it, Im not sure what he has done, (maybe some tuning, headers, exhuast, stuff like that) but his license plate says, DONT TRY, haha, he thinks its the fastest thing on the street. Making the 79 smoke his stupid camaro is kind of a goal, but Im not building the car aroud that.
Thanks for any help anyone can give.
Old 07-08-2010, 08:07 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'd want more rear gear and a looser torque converter for that cam.
With the potential of those heads, I would also use more cam, but that's only from the standpoint of a weekend toy-type ride. It's easy for ME to say, but YOU are the one footing the bill and riding the ride- but just sayin'. lol
A 750 DP would work well w/that deal, even as you've spec'ed it.
Old 07-08-2010, 10:03 AM
What size rear? Like 4.11 gears? The 3.73 I through out was just out of what I have seen most people use, by "seeing most people use", meaning what I have read. I can go with a bigger gear, Im not scared. Also, what size of cam would you recommend? What do you mean by, Looser torque converter for that cam? like a 3000 stall? Sorry for barrage of questions, still learning. Thanks
Old 07-08-2010, 10:51 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
My "recommendations" are more 'bench racing' with you, than anything set in stone.
I'm just looking at those heads and thinking how to best use their full potential- which would mean a lot more of everything!
AFA the gear ratio, one way around needing such a steep gear (like the 4.11/4.56) is to use a TH700R4 or a TH2004R tranny. They have a first gear that will let you use a 3.73 rear gear (better than a 4.56 because of the driveshaft speed being slower w/the higher gear [lower number]). This is beneficial from several standpoints like wear on the U-joints, a stronger pinion gear, less vibration issues.
Picking a cam at this stage will pretty much mean the engine and chassis/drivetrain will be built around it. That's not necessarily a bad thing, as long as it's understood that it all has to mesh together as a whole.
The combo you spec'ed at the start isn't bad- it just leaves a lot on the table is all. And THAT'S not necessarily a bad thing, either. It leaves room to "grow" should you decide to pick up the power later on.
Hopefully there will be other opinions on your deal.
Old 07-08-2010, 11:15 AM
haha, hey brother, I totally understand what you are saying. I married into this 79 and my wife refuses to do get rid of it, so I have to rebuild it. This all started out with simply replacing the 305 in it now with a 350, which lead me to find out a 383 stroker will put out more power and torque and not be much more cost over a 350, which lead me needing to rebuild the TH350 and a better stall converter, which lead me to having to rebuild the rear end and put in a posi, that went to the brakes needing to be upgraded to disc (gotta stop the beast) which lead to needing bigger rims becuase of the disc. So building an engine around a camshaft is the same as building a car around the engine. Its one thing after the other.
But like i said, everything is subject to change, but I want to try and stay away from the continual 'one-up'. Meaning, I am evening thinking about going with AFR 195 heads which are only about 75 bucks more. If I need to go with a 700 trans, I guess I need to get it done. I was wanting to rebuild as many of the components as possible, like the trans and the rear end. However, the last thing I want, is to leave anything on the table, I would like to get all the right stuff working together the first go which is why I want to get as much advice as possible during this planning phase. I want to get this WHOLE drivetrain figured out, get it set and stay on the course while I build it up. The plan right now is to have the whole drivetrain built up and ready for install, then I am tearing the car apart, so when I rebuild the car, I can have the drivetrain ready for install. Thanks for the help
383 Build Questions ERacerX Engine 7 06-14-2010 10:04 PM
New SBC 383 build question + parts list Filmjay Engine 40 04-25-2010 09:25 PM
need pointers on 383 build muddin_wolverine Engine 5 10-31-2008 02:21 PM
383 Build Up sexypizzaman Engine 1 03-22-2006 09:46 AM
.60 over 383 SBC Questions Mustangsaly Engine 8 06-28-2005 12:18 PM
