Yet another 700R4 question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2004, 07:23 PM
my350camaro84's Avatar
Smoke Tires, Not Drugs.
Hey hey guys I've got a LOVELY 700R4(notice sarcasm) well I'm really to lazy to do all the work that comes along with changing out a Turbo350 for it so I'd really just like to get a shift kit and maybe do some others to it. Any suggestions? or screw the 700R4 and go with the Turbo 350? The only reason is that I got the Turbo 350 free in working condition so I'm kinda at a loss whether it's worth changing all that speedometer programming and whatnot if I could do some work with the R4 and get the same response.
Old 11-29-2004, 07:38 PM
New Member
700 R4
Hello-
The only upgrade i ever did to a 700r4 that really worked was installing a manual shift valve body from tci. It even get's rid of the detent cable (weak link if adjusted even a little wrong) But if you don't like the idea of manual shift it won't be the option you'll want to go with.
Old 11-29-2004, 07:43 PM
nah manual shift doesn't really bother me to much but if I do that I mind as well go through the trouble of getting something like a T-5 but that is quite a bit of work.
Old 11-29-2004, 08:46 PM
New Member
But you would still be a automatic with the 700r4 in the since you would not have a clutch to push when you shift plus you can install the valve body with out removing tranny. with the tci valve body you will have a huge improvement in tranny live.
