Yet another Air Compressor Piping Question..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2010, 05:42 PM
I have a 3/4" outlet on my Ingersoll Rand 7.5HP 80 Gallon compressor that goes to a 3/4" copper piping system.
However, the inlet / outlet on my (free) Permea air filters are only a 1/4"
Is this big of a step down going to negatively impact the air volume the system produces? I have one filter located between the air compressor and dryer and one filter located between the dryer and air pressure regulator.
I will be operating various air tools, spray guns, media blasters, etc.... The compressor puts out 24 CFM @ 175PSI
Should I get rid of these air filters and buy ones that are at least 3/8" or 1/2" even ?
Old 03-23-2010, 06:47 PM
Old Fool's Avatar
To give you an idea of how restrictive the 1/4" sizing is:
1/4" schedule 40 pipe =
max recommended flow rate of 20 scfm@150 psi
max recommended flow rate of 13 scfm@100psi
3/4" schedule 40 pipe =
max recommended flow rate of 115 scfm@150psi
max recommended flow rate of 80 scfm@100psi
source: http://www.engineersedge.com/pipe_flow_capacity.htm
I am sure Old Red will jump right in here and correct me about this.
Old 03-25-2010, 09:57 AM
That answers my questions....my 1/4" air filters are going up on Ebay and I already bought some Numatics 1/2" ones. Thanks!
Air Shocks Question leejoy Suspension - Brakes - Steering 5 02-26-2009 06:32 PM
Air Conditioning Removal question Jayl13 General Rodding Tech 3 01-28-2007 09:34 AM
Question on air supply setup for painting PurpPplEatr Body - Exterior 25 05-03-2004 05:43 PM
Air Cleaner Question Jag Daddy Engine 2 04-04-2003 07:27 AM
