yet another chev starter prob - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2011, 10:49 AM
85 silverado, 350, tried shimming, and it started grinding, took the smallest shim out, now it sounds and starts like its shimmed too close, 2nd starter, 2nd set of shims, once i replaced the starter, it started just fine the first dozen times, but after the motor got to operating temp, is when the trouble started, any guesses?
Old 01-07-2011, 10:54 AM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Have you checked the clearance of the flywheel and starter gear when it is meshed. I see you are messing with the shims but you must also take measurements when changing them around..
Old 01-07-2011, 11:19 AM
not sure how, this is the first time ive had this problem, and what specs should i be looking for?
Old 01-07-2011, 11:31 AM
pepi's Avatar
A large paper clip will give you a good mesaurment, .020
here is a link to check out
http://answers.yahoo.com/question/in...5230519AAf8atQ
Old 01-07-2011, 11:49 AM
pepi's Avatar
Here is a link with pictures to show what you are after I'd stay with the .020 measurement cause it is kind of middle of the road..
You want to make the measurement for the clearance between the starter gear and flywheel in figure 1,
not that backlash pictured above figure 1
http://www.hitachi-hap-la.com/Downlo..._PE_106-en.pdf
Wiring a mini starter in a points system on 350 Chev. modelateacher Electrical 5 03-06-2008 11:52 AM
New High Torque Starter Connection prob . tony72 Engine 2 12-30-2007 06:24 AM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 02:44 PM
starter prob chevelle ss427 Introduce Yourself 6 10-21-2007 02:51 PM
starter snout breaking off 454 chev ratlover Engine 14 03-13-2004 03:45 AM
