yet another ford 9 inch question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2006, 09:50 AM
leldai73's Avatar
Its just metal,you're the boss
Once again in my quest to beef up my drive train Ive hit a road block....i am trying to identify what gear ratio I have in my 9-inch and would like to do it without removing the pinion and counting teeth. i have since my last post removed the third member and discovered it to be an open carrier which i must replace eventually...cant have a one wheel wonder. at any rate...
the numbers one the ring gear (the id tag is long gone) are:
"U A-D2TW4210-a (what appears to be part of a B or E) 035"
the axle is a 31 spline from a 1979 F-150...i dont know if that information is relevant...but i'll throw it out there just in case.
I have been scouring the internet and hotrodders.com trying to decipher these numbers and find out my ratio and have come up with nothing...so i once again humbly ask for you kind folk's assistance. any help will be greatly appreciated, and once again, a merry Christmas to all of you.
Old 12-25-2006, 10:24 AM
In the time it takes you to 'scour the internet' you could count the teeth. You can always rotate the yoke x number of times, enough to cause one revolution of the ring gear.
Old 12-25-2006, 10:37 AM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Its simple...... divide the number of teeth on the ring gear by the number of teeth on the pinion gear. This will give you your ratio.
Old 12-25-2006, 11:57 PM
Bare Knuckles Champ
Last journal entry: Made a wrench...
1- Grease mark the ring gear where it sits at some distinguishing feature (ie: mark this also, so you know when they line up).
2- Grease mark the yoke & a corresponding point on the case, so you know when they line up.
3- Turn yoke & count rotations until the ring gear marks line up again. This is your ratio. ie: Four and 1/10th turns would be 4:10 or 4:11 gears. And so on...
Good luck.
Old 12-29-2006, 07:23 AM
Ford 9 in question
Yeah not sure How much help I can Be ? Been 13 years since I done a 9 in ! But Hopefully this will point you right direction ! Ok Ford 9 in Covers Lotts of Years in Ford Trucks Here are Basics best I remember them . Think Axles Come in 2 Basic types 31 Spline and 32 Spline ! Ok F-100 Series trucks that came with 6 Cyl Motors Generally Used a Single Pinion Houseing in there Pumpkin But Pinion houseing is Usually set up so that a 2nd Pinion Gear can be installed . Usuall Gear ratio If Memory serves me is 2.77 Now With the F-150 Series I Beleive came with 302 or 5.0 and the 460 Was Availiable . I Beleive the one your Lookin for would have Come With the Big Block 460 << Ifn Memory serves me Correctly the F-150 With Big Block 460 Had the Dual pinion houseing << Has 2 Pinion Gears in Pumpkin and I beleive that it was the 32 splined axle with a 3.83 ratio << Beleive this is the one Highly sought after by the American Hot Rodders ! Now Keep in Mind Variations of trucks As In Ford Exploder's Were Sport Model Truck's << Meaning you might find this gear ratio in a Exploder version of the F- Series Truck's Possibly with 351/ CID 400 . As To Identification I Can only Tell you Count Teeeth And Axle Splines Both ! As You will need the Dual Pinion gear Houseing too Match Axle splines . << Hopefully this will Be of Some Help too you ? About all I can Remember of them . Except Pumpkins are Lil Spendy I think I paid 400 Buck's for the Dual Pinion Pumpkin 13 Years ago here in So Cal . <<, Meaning you might wanna Look around Some Back yards , afore Venturin intoo the Realm of Auto Salvage . Hopefully I memberd this right ? But You gett the General Gist of it , and what your lookin for ! Sean
Old 12-29-2006, 07:43 AM
powerrodsmike's Avatar
Wiki Edits: 161
I been saving this one.
BE different....ACT normal.
Old 12-29-2006, 07:57 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Ha Ha Ha....Good one Mikey!
Old 12-29-2006, 08:00 AM
aka Duke of URL
This is the actual I.D. stamping on the RG. There will also be one on the pinion gear. To positively identify what you have you need both ID's. The RG and Pinion Gear can be interchanged with others (factory asm) to arrive at different final ratios.
With the carrier removed, simply count the gears on each and divide.
Old 12-29-2006, 07:43 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Are you saying that a particular toothed pinion can be installed to another ring gear with a different number of teeth than the original mating?
like taking a 10/35 and using that same 10 pinion to make it a 10/32 or something???
You're kidding, right?
Old 12-29-2006, 10:05 PM
Wiki Edits: 161
I think KULTULZ would have to be having one hell of a senior moment to imply something like that.
Later, mikey
which 9 inch Ford to use dbell Transmission - Rearend 3 02-28-2006 07:17 PM
9 inch ford to 56 chevrolet ray bob Transmission - Rearend 3 01-27-2006 03:19 PM
Ford 9 inch to Chevy 4.75 pattern questions 3100 Special Transmission - Rearend 14 01-21-2006 07:29 AM
9 inch ford setup question Eric327 Transmission - Rearend 8 01-18-2006 08:31 PM
1973 Ford 9 inch disc brake conversion question Steve-0321 Suspension - Brakes - Steering 2 12-17-2005 08:47 PM
