Yet another MII drop spindle question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2005, 03:35 PM
1948 thames's Avatar
Seller told me that the spindles I bought are forged steel one piece american made, but now that they have arrived I don't think so. I believe they are 2 piece, but still maybe forged because of the wide parting line [kind of like a parting line on a cast vs steel crank shaft] on them. My question is should I try and make him make good on the deal, or just use these? These are my first set of drop spindles, so I am not sure how safe these will be.
Old 06-21-2005, 04:15 PM
"One-piece" spindles??
It is a mystery to me, this description of "one-piece" unless perhaps they are considering the spindle as only the ball joint to ball joint forged piece and the inserted piece a stub axle(a UK-style description).
As far as I know all aftermarket spindles are made this way.
Old 06-21-2005, 05:52 PM
I have seen them advertised as 1 piece and I have heard some made of cast iron with pressed in stub, instead of forged steel. It's confusing to me, but as long as these are forged steel I guess they should be OK. I still think the wide parting line confirms these are forged but I am not 100% sure and if forged why not one piece?
Old 06-25-2005, 11:44 AM
Someone on another board say these look like cast instead of forged. Can anyone explain to me the difference in appearance between cast iron and forged steel.
Old 06-25-2005, 02:11 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
My spindels
All of mine look like what you have and they are the stock ford spindles..as far as the 2 piece is concerned..that is the way they are made..the steel required for the "axle stub" is a different thing than what is required for the "spindle"
You can run a Spark Test to help you determine just what kind of metal the spindle is..
As far as how they look in the picture, they look very similar to what I have here and I know mine are the stock ford spindles..
Hope it helps
OMT
Old 06-25-2005, 10:35 PM
Thanks for the reply. There are some one piece forged spindles being made and thats what I was told these were. I would feel better if I knew if atleast they are forged steel and not cast iron. I looked up spark test on google and couldn't come up with anything. I don't know that much about drop spindles, so maybe I am being paranoid, but I will have my life riding on then.
Overheating and a/c question.. Meangreen General Rodding Tech 28 06-23-2004 10:02 PM
Hotrodders Guidelines -- READ ME Jon Interior 0 06-14-2003 04:59 PM
Hotrodders Guidelines -- READ ME Jon Transmission - Rearend 0 06-14-2003 04:58 PM
Hotrodders Guidelines -- READ ME Jon General Rodding Tech 0 06-14-2003 04:57 PM
Hotrodders Guidelines -- READ ME Jon Engine 0 06-14-2003 04:53 PM
