Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Yet another question about bonding fiberglass to metal
Old 01-07-2004, 09:16 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
You are getting blanket statements that it won't work because it won't work! Sorry. The only way I would try that is to build the fender flare, then encapsulate the entire fender in a couple of layers of 'glass mat & resin so the outer surface will be all one material. This would give you a fighting chance.
