I'm back, this time with a new problem. Last Sunday I pulled the truck in the garage after going through a huge rain storm (I dont have inner fender wells in the front). A wire came loose from my alternator and I barely made it home. That was my first problem, easy enough. Today, I went to start up the truck and nothing. Turn the key and nothing. I crawled under there and found that I melted through one of my starter wires. Second problem, easy enough. or so I thought. I fixed the wire and still get no responce when I turn the key.
I took the starter out and checked it. It works fine when hooking it up to a 12 volt source so that isnt the problem. All my wires are good now with all good connections so that isnt the problem. What else should I check / look for to get my truck on the road again. This is so strange??? It worked fine then BAM nothing at all. Also, I have good power - battery is at full charge now and no fuses are blown at all???
Help me out here......I'm goin nuts trying to figure this one out. THANK YOU in advance!!!
Shawn -
