Yikes. More polishing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2006, 08:59 AM
cboy's Avatar
Last journal entry: Finished
After finishing the intake manifold and swearing off metal polishing FOREVER, I was right back at it yesterday. Please. Somebody. Come and burn my stash of sandpaper. Get me into detox.
At least this ignition module was was a LOT easier than the manifold - about 1/100 the surface area and not nearly as many nooks and crannies. Total time, including the paint work, was about 8 hours. The "before" shot in the first photo is actually not the same module (this one's off the rat roadster) - but it's virtually identical (except for the letter inlay) in terms of the surface texture you have to work with.
The second shot is the completed polish job. I couldn't figure out a way to get down between the letters (which are recessed) so I opted to paint the background the same color as the truck and then took off the paint on the letters by wiping them down very carefully with lacquer thinner.
Before:
After:
Dewey (nubs) Lindstrom
Always learning...and sharing what I've learned.
Old 04-06-2006, 10:55 AM
Awesome job!
Old 04-06-2006, 03:27 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
maybe you ought to put in user name change request....
nice work Nubs.
Old 04-06-2006, 06:59 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
is the recent influx of polishing threads on this site inspired by Our Hero, Polishing Ron? lol...
it looks wayyyy better polished than it does stock!
Old 04-06-2006, 08:59 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
how come the parts look different? the logo has a banner on the polished one with a relief and the mounting holes are also different @ the wires, the other set of holes also look bigger and with a different placement , man you really do a lot with that polishing
Old 04-06-2006, 09:12 PM
cboy's Avatar
Originally Posted by pepi
how come the parts look different? the logo has a banner on the polished one with a relief and the mounting holes are also different @ the wires, the other set of holes also look bigger and with a different placement...
pepi,
Check the second paragraph of the original post for this thread which explains what you are seeing. The "before" shot is the module I have on my roadster and the module I polished is for my pickup. They are identical, interchangeable, Ford modules - except for the way the logo is cast in the case.
Old 04-08-2006, 07:50 AM
dinger's Avatar
Nice work, Dewey! I think I'd mount that puppy as a hood ornament, it looks that good. Dang shore would want it seen. Dan
Old 04-08-2006, 10:59 AM
looks good Dewey...now that your practiced up real well...wanna come over and polish my tri axle dump truck and 24' aluminum dump trailer??
Old 04-08-2006, 11:54 AM
cboy's Avatar
I'm not THAT crazy.
Old 04-08-2006, 02:47 PM
Race The Truck
Last journal entry: Son's Truck
Wow, nice job.
Craig
Old 04-09-2006, 06:35 AM
Vortech 4.3's Avatar
jack of all trades
looks good. sometimes polishing isn't sooooo bad .
maybe try this. next time you get a tough spot, like those letters. see how thick the metal is. and if its thick enough, use a rol-loc or a flap disc and grind off the difficulty. not only will that make things easier, but it will give a smoother look.
Old 04-09-2006, 07:00 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
OK.....Whats next?
Old 04-09-2006, 05:40 PM
cboy's Avatar
Originally Posted by Henry Highrise
OK.....Whats next?
I'm thinkin' Schnitz's bald spot.
Old 04-09-2006, 07:37 PM
Lost in the 60's
Wiki Edits: 4
When ya get through...if you post a pic of that... give me a warning so I will know to put on my welding helmet.
Old 04-11-2006, 09:28 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Its magic!! like a geine in a bottle .
polish it & it get s bigger . . .oh wait thats a different story
I got a 32' Airstream but I think that will just get sanded & clear coated
but this will work
nice job CBOY sweet!
R
"SlowRide66"
"Illegitimis non carborundum"
Manifold polishing FINALLY done cboy Garage - Tools 27 04-08-2006 04:20 PM
Polishing compounds question Jag Daddy General Rodding Tech 1 07-21-2004 01:11 AM
porting and polishing heads 69elcaminoss Engine 22 04-22-2004 10:42 AM
Polishing my aluminum wheels 78SilverShark Body - Exterior 4 12-20-2003 09:56 PM
Port and Polishing Job DTL504 Engine 10 11-16-2003 04:09 PM
