yoauto - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2005, 08:33 AM
Lowering a 65 Galaxie
Wanting to lower a 1965 galaxie.Don't seem to be able to find drop spindles for this year. Any help or ideas?
Last edited by yoauto; 12-31-2005 at 08:58 AM. Reason: Getting to the reason for post
Old 12-31-2005, 09:39 AM
As the Moderator, I would like to WELCOME YOU here.....
I have a few friends with mid 60's Fords and they end up changing springs to lower them . A few cut a coil or two off the original spring.
Old 12-31-2005, 10:01 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
If you want to keep the original geometry and springs, you can always cut the A-arms and offset with plates and gussets. (This would be the equivalent of that unavailable dropped spindle.) Really not all that difficult if you know what you're doing with a welder. Go to my photo gallery and you'll find a picture (not too difficult since it's the only picture there). In this case, a Pinto outer tip is being adapted to a British Sprite lower arm so I could use the Pinto spindles and brakes. Since the Sprite uses the shock absorber for the upper control arm, a custom tubular upper arm is shown in the picture. In your case, the same procedure would be used on both arms.
yoauto yoauto Introduce Yourself 4 12-31-2005 06:42 PM
