Yoke identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2013, 07:55 PM
Yoke identification
I 'm trying to find some info on a yoke on my ford 9". It is not the standard 1-9/16 x 3-1/4 or 1-9/16 x 3" nor 1-7/16 x 2-7/8 u-bolt centers but measures 1-7/16 x 3-1/4". Any help is greatly appreciated
Old 02-17-2013, 10:01 AM
S10xGN's Avatar
Gotta love a turbo!
I'm not understanding your first dimension, those numbers are too large. Perhaps you should look here until you find the right one.
Russ
Old 02-17-2013, 11:04 AM
prostreet6t9's Avatar
Differential/Driveline
Need better measurements please. Use a micrometer
Old 02-19-2013, 02:58 AM
Wiki Edits: 85
If I am reading this correctly, you are telling us that your u-bolts have threaded ends 1-7/16" apart instead of 1-9/16". And the distance from one u-bolt to the opposite u-bolt is 3-1/4" instead of 3" or 2-7/8". Am I reading this correctly?
Clean your yoke thoroughly, then look for casting numbers on the yoke. Usually they are in the saddle(s) that are 90 degrees rotated from the cups. Sometimes those numbers help identify yokes.
Using a bolt in yoke as a slip yoke 0trbo4myCHEVUICK Transmission - Rearend 8 08-06-2012 10:35 PM
Do they make a shorter yoke on the 9" ford differential, or trans yoke grobb284 Transmission - Rearend 4 07-17-2009 08:57 AM
What Yoke? 39chevy Transmission - Rearend 2 02-21-2009 10:27 AM
TH400 Can I replace a fixed yoke with a slip Yoke? Double_v23 Transmission - Rearend 4 08-07-2008 06:31 AM
How far in the yoke should be?? camaro 68 Transmission - Rearend 3 03-10-2004 11:44 AM
