You guys are real pros - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2005, 02:38 AM
This site is totally awesome and is a great wealth of information. This may seem a bit trivial to most of you my next question but here goes:- Does hardner for 2 pac have a shelf life when opened?
You see I used some clear a while back and it worked wonderful but I didnt use a whole lot of it. After about 6-8 weeks when I was to use another mix it formed a milky sort of look when the hardner was added to the clear! (No I didnt use this batch on the work but got new hardner).
Im assuming that moisture got to the hardener or went OFF! I came to this conclusion that after buying new hardner it worked fine without this milky clear so then the 2 pac body clear was OK!
Can anyone explain if they have had this happen? Ive also had some older stuff hardener that actually formed "flakes" in the 2 pac for what reason I dont know!
Has anyone experienced anything like this themselves???
Thanks peoples!
Old 06-20-2005, 08:00 AM
You are very right, the isos in the hardener are very moisture sensitive. There are products out here that you can put an innert gas into the can when you put the lid on and it will save the product from failure. I have even heard of guys using their mig welders argon for this.
But if you clean the threads on the can and cap and tighten it well it will last a number of months or even years without "milking" up. This depends a lot on how much is gone from the can (how much air and moisture got IN in other words).
Old 06-20-2005, 10:53 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
I have a can of clear that i tried that on, it's been setting up for over a year now, maybe i should see if it's still any good?
Just got home from Good Guys @ IRP! frankenvette Hotrodders' Lounge 2 06-12-2004 10:56 PM
First time here. And a pic of a real jerk! Couple pics. 52Caddy Hotrodders' Lounge 16 06-08-2004 08:56 PM
SBC running at last - thanks guys & HotRodder.com Limey Simon Engine 0 04-28-2003 05:03 AM
What do you guys think of the new GTO? '54-Hunter Hotrodders' Lounge 20 02-11-2003 07:02 AM
(?)Poor guys excluded!(?) 78 monte Hotrodders' Lounge 46 06-26-2002 03:07 PM
