You like High RPM, watch!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2012, 01:52 AM
12,000 rpm nova... its just a little sbc 30 over 283.. has a nice sound of its own!!!
http://www.youtube.com/watch?v=xv251lDtGu0
Old 06-19-2012, 08:11 AM
Banned User
i like it. i also like small cubes. i'm open minded to it, but how much did it cost to achieve this?
I'm thinking it's probably cheaper to go conventional-----cubes plus maybe a supercharger or nitrous.
Old 06-19-2012, 08:41 AM
Wiki Edits: 27
ultra rev
Back in the early 60's I helped a buddy build a high reving chevy( WE were both in the Same Auto engineering classes in college) New 327 -375 HP long block, we pulled the new engine down and installed a roller cam and the Ultra rev kit. a steel plate under the heads and springs between the plate and roller lifters. double checked all the spring pressures, polished and weight matched the valves I think he didn't reve it past 8500 but it sounded sweet. I did a 292 ford that would really rev. 7500 rpm when most fords wouldn't go past 5500.
Old 06-19-2012, 08:49 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Great video!
I love high revving small blocks, Chevy, Ford or Chrysler, Chevy is the cheapest to build.Ive built screaming 283s and 302s and destroked 350s with 4 bolt mains to 302! for less then building a 383 stroked 350! Its not that hard. piston speed in strokers like 383s at say 7000rpm is much faster then in a 283 at the same 7000 rpm ( many builders dont relize that fact) But the destroked engine has far less torque to get you moveing!!!
Jester
For full story click here:
http://www.z28camaro.com/oldrel.html
Old Reliable
TECHNICAL DATA
Engine Data Cubic Inches, 302
Cylinder heads #3917291, completely stock, no porting allowed!
Stock rocker arms & valve springs
Intake 302 aluminum intake, casting #3917610
Carburetor Holley, #4053, 780 CFM 4bbl
Camshaft Crane, .480 inches lift, 272 degrees duration, valve lash, .016-.016
Pistons GM 302, .030" oversize
Horsepower 456 @7700rpm
Rear Tires 9" x 30.0" Hoosier's
Rear axle & ratio 12-bolt, 5.57 Richmond Pro Gears
Clutch 10 inch, three finger from Advance Clutch Technology
Shift Points 8200 RPM
BEST ET 10.80 @122.30mph
Old 06-19-2012, 09:20 AM
http://bangshift.com/blog/the-partin...the-floor.html
Jester
Old 06-19-2012, 11:39 AM
yeah my dad back in the 70"s they used to destroke a BBC, they took a 427, destroke 5/8 of an inch, ran 4 speeds of course.. Dad said he used to shift at around 8000 rpm, crossing the traps around 9,500 rpm.. lol thats cranking.. He went to a inline shifter from an H patteren, he didnt have the shifter setup quite right and missed a shift.. went from 2nd to 1st and gernaded the motor...lol
Old 06-19-2012, 11:47 AM
to achieve a build like this guy, it would cost you more now days than to build a torque moster bbc 454... destroking was the thing to do back in the day untill bigger cubes came along and was easier on the vave train to turn a engine at lower rpms and make a ton of torque... destroking is still done today so dont let them fool ya, some of these engine will still out perform the bigger cubes motors when setup right...
Old 06-19-2012, 11:50 AM
painted jester...... Yeah have agree there on piston speed.. yes most guy do not realize this factor when building a race engine or street motor.. altho street motors dont always turn the higher end rpms as a race engine, but still a build factor to point..
Old 06-19-2012, 11:53 AM
One thing i like about this video as it shows possibly how much more you need to turn a short stroke engine to produce the torque to get it to move compaired to a longer stroke engine AKA {big block}
Old 06-19-2012, 12:12 PM
bearing speed is another factor at high reving engines, thats why nascar engine run a 1.89 or even a 1.50 rod bearing... I know the NHRA prostock big blocks run a machined connecting rod to run a smaller bearing from a SBC 2.1 or even 2.0 on there rods to cut down on bearing speed, heat and friction
Old 06-19-2012, 09:18 PM
1971BB427's Avatar
That Nova launching wheels up seems to have plenty of power! What a great video!
There are those who say that high winding smallblocks wont make good power, but I think they haven't tried building one, or at least not given them a good try.
I've always been a fan of the old 301 SBC combo and the 283. Both can be so much fun hanging out in the high rpm range, and doing it so effortlessly. My present car is running a little 327 that I wish the budget would allow a destroke, but it's a late model large journal 327 and the cost of destroking is a bit higher than it was with the old small journal 327's. It still pulls 7,000 rpm's with a 2 bolt main assembly easily, but I'd love to make it a 301 someday!
Old 06-19-2012, 11:17 PM
valve train durability is the biggest issue with high rpms... this guy I believe ran titanium valves to help lighten up the valve train a bit making it stronger as well... There defantly is no sound like a high winding SBC.... defantly pretty cool!!
Old 06-19-2012, 11:30 PM
Originally Posted by painted jester
Great video!
Jester
[url]http://www.z28camaro.com/oldrel.html[/ur
Old Reliable
TECHNICAL DATA
Very nice artical Im a big fan of the first gen camaros.. I own a 67.. I bought mine as my first car bought while i was still in high school which i still have.. ive been out of school since 91..lol
Old 06-20-2012, 07:20 AM
Banned User
Ok, but how much would it cost, approximately, to have an engine like the one in the nova?
The other thing is, i feel, a more conventional "low rpm" chugger would be more reliable.
i want to race frequently at different tracks and have no or little maintenance. i would rather concentrate on racing as opposed to frequently tinkering on the engine. Or course some people love constantly working on the engine.
Old 06-20-2012, 08:26 AM
That was nuts, and that launch was awesome
Rpm too high!! Cerry Engine 10 07-01-2010 01:04 PM
rpm too high jjj Engine 4 09-14-2009 10:29 AM
Too High RPM? Riverman Engine 6 09-06-2005 10:53 PM
Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High. white66coupe Engine 11 09-10-2004 11:49 AM
