Your biggest parts purchase yet? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2004, 07:36 PM
Carbed95GT's Avatar
Evil as I wanna Be
Last journal entry: First time out in 8 months!
Lightbulb Your biggest parts purchase yet?
What is your single most expensive purchase for your cars?
Here's my list.
95 GT: 347 stroker
89 LX: Paxton Novi 1000 (I sold it 400 miles later)
95 GT(hubby's): Kenne Bell 1500
Old 01-30-2004, 07:43 PM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
Mine will be soon...
*4link rear setup
*4 airbags
*Air Tank
*Compressor
*Front Bag Brackets
*Shock Relocation Kit
*4 Electric Valves
*Bridge Kit
*Step Notch Kit
*Spun Alum. Gas Tank
*Misc, hose,fittings,wiring for air-ride
Then after that I have left to buy is....
*Wiring harness
*Motor parts
*Wheels
*Tires
*Paint
*Upholstery
*etc
*etc
*etc
I am shooting for summer time to have my truck on the road, moving under its own power and suspended on AIR I don't even care if I get the paint and interior done by summer, I just want to drive it!!!!!!
Later,
WEIMER
Old 01-30-2004, 09:31 PM
onebadmerc's Avatar
I need a bucket of arc sparks
The most expensive purchase I have made so far for any of my vehicles is my 2 4 barrel carb setup. If I decide to dump the T10 this summer and put in a WC T5 or a Tremec that will then be the most expensive thing on my car.
Old 01-30-2004, 11:07 PM
Crazy Mopar Guy's Avatar
My biggest purchase was for my engine for my Coupe, $45,000+ Canadian.
Old 01-30-2004, 11:22 PM
RetroJoe's Avatar
Beats pickin' cotton
I bit the bullet and bought a disc brake conversion kit, frontend kit, rear bushing kit , new top,carpet,rear seat cover,window fuzzies, and a few other misc. items at once and spent about $2300. The disc brake kit was the largest chunk of the dollars spent.
Old 01-31-2004, 12:36 AM
Chevy Thunder2's Avatar
The sad part for me is I can name most of the expensive parts I've ever bought I guess its not too bad at 17
*Accel Ignition
*2 Edelbrock carbs 600cfm and a 750
*Edelbrock Performer intake
*B&M Stage 2 shift Kit
*And here is the most expensive thing I've ever bought for my car...Pioneer 9500 Cd/Mp3 player $1100, it is nice though (I'm a compulsive buyer and I was mad at my parents so I spent all of my 173hours of work on it)
Old 01-31-2004, 09:57 AM
38 special's Avatar
Be the MIRACLE!
Last journal entry: Running boards (part DUEX)
To date, probably the gas tank, 215 bucks. Not bad really.
Old 01-31-2004, 11:11 AM
Rhansen's Avatar
Footbraker
Biggest chunk of money I've put out for my POS was $1950 for a narrowed 9" rear w/locker, 3.50 gears, Moser 31 spline axles, SSM lift bars, slotting the lift bar spring pads for the different U bolt pattern, redrilled brake drums, all brake hardware, ARP wheel studs, and installation of above in my PU.
Old 01-31-2004, 12:09 PM
flamedfordbronco's Avatar
Last journal entry: finished
the most expensive part I bought for my car was the air ride kit. lol it cost 15 times more than what the car cost me!!! But, the car was a hundred bucks, so I guess I can't complain .
~Frank~
Old 01-31-2004, 04:58 PM
Tazz
biggest expense fo far
My 377 stroked 350sbc. I don't know about a blower on a car that do's most its time on the street. I don't plan to race all that much and still running low compression, maybe a 100hp hit of nitrous oxide just for laughs. LOL LOL
Tazz
Rat Rods Rule!
Old 01-31-2004, 05:06 PM
poncho62's Avatar
Wiki Edits: 5
The most that I ever spent at once on my hot rods, was $500 for 2 front fenders for my truck. I spend as little as possible by buying a bit at a time and doing everthing myself.
Old 01-31-2004, 11:49 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Does it count if it's not your money?
My next purchase will be a super late Rayburn rolling Chassis $20,000
A few tires(8) at 144 a piece
Seat and guages and Misc ****pit stuff $1,000
770 horse 388 by Hendrens Racing engines $28,000
A trans and 5 disc clutch 3,000
A night at the races, wide open throttle in a four wheel power slide into a 180' corner on dirt!! $priceless
Old 02-01-2004, 04:31 PM
badknuckles's Avatar
you talkin to me?
heads- 60$
head work-300$
springs-90$
roller cam-300$
timing chain-120$
crank-300$
intake-35$
carb-50$
headers-108$
hv oil pump-60$
rebuild kit-125$
not to bad for a 300+hp motor everything else was free
Old 02-01-2004, 11:44 PM
Chief Pontiac's Avatar
Live free or die
Had my Turbo 400 in my 1970 T/A rebuilt with all new parts $600
Had some minor paint work on same car $600
Old 02-02-2004, 10:37 AM
k2mooch's Avatar
'69 Mustang Coupe $700
'84 351 W $350
Starter $25
Radiator $110
C5 auto rebuild bench job $400
Auto Meter Ultra Lite Tach 10k/rpm $90
Summit Air Cleaner $15
Transmission Fluid $60 (I've tried 3 different trannys so far with no luck)
Hedman Long Tube Headers $90
Duraspark Ignition Module $35
Water Pump $35
Hoses $25
Trans. Mount $15
Eng. Mount Frame Brackets $120
Engine Mounts $30
Misc. Gaskets, Seals, Wires, Bolts, Etc ~$80
Aproximate Total $ 2,179
Holy cow, I had no idea it was that high already.
All I need left is to run exhaust, new fuel lines, fuel cell, manual steering conversion, new wheels/tires, rust repair, body work, paint. Hmmmmm I guess about another 4 grand and about 2 years and I should actually be able to call it a car. Till then, it's just my favorite drinking seat in the garage.
MoocH
