Your Fastest ET, how fast and what combo? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2005, 12:25 AM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
What's the fastest you've gone with your quickest rod?
Was it a xxx ci?
Did you run hyd, solid, or roller?
what heads, stall and gears?
What body and what weight?
Nitrous, Turbo, SuperCharger?
Was it reliable?
What Rpm did you shift at?
What was your trap speed & MPH?
My fastest at the track was a 358ci, RPM cam, ported 882 heads, 2500 stall, 4:11 gears in an '82 firebird. Drove it 80 miles to the track, made one pass with it missing so bad i was flipping the 125hp NOS switch wondering what was going on. On the look the dizzy cap came loose. I used my shoestring to tie it back on and drove 80 miles home.
12:33 @ 110 MPH. I know it was a solid 11 second car.
My fastest was a 400SBC with a blower & 4-speed in a Monza. I never got it to the track...but it would spin 10" et drags into 3rd gear. Very fast street car.
Old 06-21-2005, 08:39 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
9.72 @135 mph
1.35 60' times
1107 cc
3 cylinder
(3) 48mm carbs
normally aspirated
10-5/8" wide x 121 " rubber
2 skis w/ rollers
Old 06-21-2005, 07:02 PM
Rhansen's Avatar
Footbraker
My daily driver (very reliable) - 82 S10 longbox
350 chevy (used motor), 882 heads, 'claimer' flattop pistons (~8.5:1 CR), Crower 267HDP 210/216@.050, 112 lsa and .444 lift, 1406 edelbrock carb, performer intake, HEI dist., etc.. (I call it my "nothing motor").
TH350, 2400 stall (12"), Ford 9" w/3.50 gear and locker (only thing I spent any money on) and a set of SSM lift bars.
The whole thing weighs 3165 lbs. (1/2 tank of gas and me in it).
Best 1/4 ET was 14.05 at 97.57 mph with a 2.15 60' on 275/60-15 Yokohama Avid ST street tires. Shifted at 5200 rpm.
I've made a lot of passes on some 235/60-15 BFG drag radials and the 60' averages 2.05 but the ET's are still in the 14.0x to 14.3x range over the season (weather fluctuation).
Driven plenty of faster cars but they weren't mine.
Old 06-22-2005, 02:45 PM
coldknock's Avatar
1/4 Mile ET: 11.15
1/4 Mile MPH: 120.82
1/8 Mile ET: 7.08
1/8 Mile MPH: 97.83
60 Foot ET: 1.57
1972 Nova. 406" sbc, 291 Lumper Thumper heads(ported by self), 750DP(borrowed),Holley Strip Dominator intake, Reed solid cam(007type secret grind), MSD enhanced HEI ignition, 11.3-1 comp., Trans Specialties 10HS converter (3800 flash), Junkyard TH350 with no accumulator spring, 3.73 10 bolt with a mini-spool, 9X29 slicks.
No front sway bar, Comp Engineering slapper bars and worn out shocks all the way around.
Larry
Old 10-22-2005, 03:24 PM
mltdwn12's Avatar
New Member
1971 (with 70 bumpers) Buick GS 4100 lbs with my big butt!
12.18 @110 mph @ 5800 rpm
455 Buick
hydraulic cam
850 Holley
stock Stage 1 heads
11" converter, 3000 stall
4.56 gears
Reliable, yup. Drove it a couple of times from the Jersey shore home to Annapolis when I was working back there. Then from Phoenix to Rocky Point in Mexico.
Craig
