Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Yukon 3.75 gears for Ford 9 inch....noise
Old 02-18-2011, 12:06 PM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
Many of the Yukon gears require more backlash than other gears. If this is a 3.70 gear then you may be having the same problem that I have had with them. I've had a few of the 3.70 Yukon 9 inch gears that had some noise in them.
