Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Yukon 3.75 gears for Ford 9 inch....noise
Old 02-20-2011, 09:25 AM
96lt4c4's Avatar
96lt4c4 96lt4c4 is offline
Would you guys mind to take a look at these patterns? I have moved this thing around every which way and can not get a good pattern. It doesnt help now that they have been driven on. The coast side is staying heavy toe. I have opened the lash all the way up to .015 and cant hardly make it move. I can bring the coast up the tooth but the drive seems to get to one point then stop moving. Would you guys run any of these patterns? I am begining to wonder if its this aluminum Yukon case. I may try to set them up in the factory cast case just to see if it helps.
