Originally Posted by big gear head
Are you changing the pinion depth too or only the backlash?
I spent the whole day moving that sucker every which way you could think. Changing pinion shims and back lash at least 50 times. I set it up in the old center section today and I think I have it. I have a pretty good pattern. The only problem is I have to change out the bearings on my trac loc to the smaller ones now. I had to put the ring gear on the open carrier that was the original to set it up.
No that I know that the gears can be set up I may try the aluminum center section one more time.
