Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Yukon 3.75 gears for Ford 9 inch....noise
  #21 (permalink)
Old 02-23-2011, 06:30 PM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
They are only marked for tooth-to-tooth position if they are a non-hunting gear set, i.e. the same pinion teeth always contact the same corresponding ring teeth. An example would be a 36-9 tooth count for a 4.00 ratio gear set or 39-13 for a 3.00 ratio set(not actual #'s, just examples)
