Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Yukon 3.75 gears for Ford 9 inch....noise
  #81 (permalink)
Old 03-29-2011, 05:24 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
You might double check and make sure the ring gear or carrier is NOT hitting anywhere on the inside of the case. Look on the side of the pocket brg and make sure the inside of the ring gear is not scraping it.
I've also had to clearance the Aluminum case because the Hat side of the carrier was scraping.
Just something to double check.
