Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Yukon 3.75 gears for Ford 9 inch....noise
  #84 (permalink)
Old 03-30-2011, 06:49 AM
96lt4c4's Avatar
96lt4c4 96lt4c4 is offline
Originally Posted by TimoFinn
I really couldn`t see anything from that video but we had allso nonuniform wear pattern in both carrier bearings and pinion bearings,one suggestion was that there were not enough preload or our 9+ case is bad.
My carrier bearings look good as far as the wear pattern on them, its just the pinion bearings. How tight are you guys setting pinion bearing preload.
