Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Yukon 3.75 gears for Ford 9 inch....noise
  #88 (permalink)
Old 03-30-2011, 09:03 AM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Originally Posted by 96lt4c4
My carrier bearings look good as far as the wear pattern on them, its just the pinion bearings. How tight are you guys setting pinion bearing preload.
I use 18 to 20 inch pounds. You dont need to run anything loose or tight because of your aluminum stuff. Set your Backlash, Pinion Preload as usual.
