Originally Posted by prostreet6t9
I use 18 to 20 inch pounds. You dont need to run anything loose or tight because of your aluminum stuff. Set your Backlash, Pinion Preload as usual.
Ok thanks, keep in mind now I will be running the N Iron pinion support. I will take it back apart and set the preload a little tighter.
