Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Yukon 3.75 gears for Ford 9 inch....noise
  #92 (permalink)
Old 03-30-2011, 10:49 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
I could see that galled and stripped off piece of aluminum causing the race to sit funny and giving you the problem you had, pinion gear would not be held in place securely under power.
Any sign on the bottom step of that bearing race bore indicating that the piece of stripped off aluminum ended up under the race and held the race tipped a bit??
