Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Yukon 3.75 gears for Ford 9 inch....noise
  #125 (permalink)
Old 04-21-2011, 07:38 AM
96lt4c4's Avatar
96lt4c4 96lt4c4 is offline
Originally Posted by prostreet6t9
Thats pretty common actually. Sometimes customers are hard to figure out and will gripe if they have to clearance the case if a thick hat is used. Other customers are fine with it. I personally always use the thick and do some grinding if needed.
I set it up last night and it clears the case but was hitting the billet cap. A flapper wheel on my grinder took care of that, no big deal at all. I didnít have to remove much material. I would rather have some off the cap than a bunch off the posi. Still getting some run out on the ring gear though. I check both ring gear mating surfaces, spinning the posi and using a dial indicator and it is dead straight. It has to be coming from this ring and pinion. I go from one thing to another. My back lash is varying about .002 around the ring gear. What is acceptable? I know going through this I have had some with no run out. This is a new Motive performance 3.89 gear. I am thinking about sending it back to Summit and trying another one.
