Yukon 3.75 gears for Ford 9 inch....noise - Page 7 - Hot Rod Forum : Hotrodders Bulletin Board
  #91 (permalink)
Old 03-30-2011, 09:20 PM
96lt4c4's Avatar
I just went back threw and looked at the pictures of the Motive gear pattern, look at the contact spots at the outer edge of the ring gear at the bottom of the picture.
I took apart the aluminum pinion support and this is what I found, a little sliver of aluminum came out when I pressed out one of the bearings. Also looks galled up.
Here is a video of the races
Look at the see patterns notice there is no contact on the bad area.
  #92 (permalink)
Old 03-30-2011, 10:49 PM
ericnova72's Avatar
More for Less Racer
I could see that galled and stripped off piece of aluminum causing the race to sit funny and giving you the problem you had, pinion gear would not be held in place securely under power.
Any sign on the bottom step of that bearing race bore indicating that the piece of stripped off aluminum ended up under the race and held the race tipped a bit??
  #93 (permalink)
Old 03-31-2011, 06:20 AM
96lt4c4's Avatar
I looked but could not tell, I am pretty sure I have found the source of my problem though. The reason the back race didnt galled was becasue we put the support on a hot plate and heated it up until the race dropped in. The outer bearing we just tryed to press in and it went sideways on us. Maybe we should have tryed the same route with the other bearing and it would have been fine. I can tell you one thing though if I ever build another one of these I will not be using an alluminum support.
  #94 (permalink)
Old 04-05-2011, 05:14 AM
Have you driven this yet? Any noise? Is the gears now Motive or Yukon?
  #95 (permalink)
Old 04-07-2011, 06:48 AM
96lt4c4's Avatar
I have been doing process of elimination. This past weekend I set up the old Ford housing with the original OEM Ford gear that came in it, 3.70. I used the new nodular iron pinion support, and the Ford racing Trac Lock that I have been using this whole time. So, now the only thing that is the same is the Trac Lock.
Something I noticed about the Yukon ring gear is that it does not fit tight on the Ford posi. I could put it on by hand. The Motive and OEM Ford gear had to be pressed on. Anyway when I took the Yukon ring gear off one of the 3 set screws that hold the 2 halves of the posi together had sheared off. The ring gear bolt holes in the posi are quite a bit bigger than the bolts, that with the ring gear not fitting tight allowed the ring gear to spin just enough that it sheared the set screws off that hold the two halves together! The hat on the posi has been machined down in a lathe, I think it has had to much taken off and is flexing under load allowing the ring gear to move away from the pinion. Here is the ford gear pattern before I ran it and what it looked like after 2 days of driving on it. It has the same marks as the Yukon gear. If anyone has any input on this let me know?
ID:	54254   Click image for larger version
ID:	54255   Click image for larger version
  #96 (permalink)
Old 04-07-2011, 09:38 AM
96lt4c4's Avatar
Just talking to a guy I work with about the set screws shearing off and he thinks my ring gear bolts are bottoming out. It makes sense i will have to check when I get home.
They are the Trac Lock bolts that came in the Yukon install kit.
  #97 (permalink)
Old 04-07-2011, 02:09 PM
I have had to run a bottoming tap in the ring gear bolt holes of many Yukon gears.
  #98 (permalink)
Old 04-08-2011, 06:21 AM
96lt4c4's Avatar
Well I had a few bolts that look like they may have bottomed out. But, they thread far enough into the Yukon and new Motive gear that i have that they should not bottom out. I measured and they go in further than the thickness of the posi so they should be good. The Ford gear is not drilled and tapped as deep as the others so they may have bottomed or came real close on the Ford gear. I went ahead and ground off a 1/16 inch off the bolts and ran them threw a die to straighten the threads. I am at a loss; I am running out of theory’s as to what it could be. The only thing left is the posi and maybe the housing not being straight. My axel slide right in with ease, no binding at all so I don’t see how it could be the housing. I am about ready to fix my 10 bolt and put it back in the car, maybe next winter....I dont want to ruin another ring and pinion until I know for sure what it is.
  #99 (permalink)
Old 04-08-2011, 11:04 AM
96lt4c4's Avatar
Ford gear, Ford housing, just found out that my posi is a Yukon Trac lock and not a Ford Racing trac lock. Yukon part number YDGF9-31-AG. Here is a video of the noise.
http://www.youtube.com/watch?v=OOVJOamkd7s
  #100 (permalink)
Old 04-08-2011, 02:43 PM
I would still suggest you try another known quiet chunk, just because you have tried so many iterations with different parts and keep getting the same results. I dont have a guess why your setup would be prone to noise transmission, but after 3 gear sets all installed with a good pattern, there is something odd going on. That is alot of noise.
  #101 (permalink)
Old 04-08-2011, 08:08 PM
96lt4c4's Avatar
I dont know, I am begening to wonder if it is my housing. Not being straight and causing axels to bind. We did do a lot of welding on it.
  #102 (permalink)
Old 04-09-2011, 06:26 AM
axle housing ---- jig it and fine out
  #103 (permalink)
Old 04-09-2011, 09:12 AM
prostreet6t9's Avatar
Differential/Driveline
I've seen your statements that the axles slid right in and out. If your housing was not straight it should be hard to get the axles in and out.
Have you double checked that your axles are the correct length for your housing?
  #104 (permalink)
Old 04-11-2011, 10:56 AM
We got ours back today,the builder said that the pattern looked terrible,but was best that could be with those gears (Motive)
He said that it probably will make some noise
  #105 (permalink)
Old 04-11-2011, 01:33 PM
96lt4c4's Avatar
When I first got the axels one of them was a little to long, about 1/16 of the wheel bearing sticking out and the axel bottoming out on the carrier pin. So we put it in a lathe and cut about 1/8 off. I got paranoid about the driver side so I put a little red grease on the end of it and slid it in. I pulled it back out and there was some grease on the pin so I cut 1/16 of of it just to be safe. I did the grease trick on both of them again and they were not hitting anymore.
I am in the process of having a friend machine me some aluminum collars to make a jig to check the housing. I can get a 1.5" bar for about $70. At this point I am going to rule everything out before it goes back together. I cant afford to keep ruining ring and pinions.
Here is what I am planning on doing, if its straight then good, if not them I have to figure out how to straighten it.
http://www.crankshaftcoalition.com/w...ar_end_housing
Changing out Ford 9 inch Gears 31fordcoupe Transmission - Rearend 27 06-04-2011 11:20 AM
Yukon gears Ford Junkie Transmission - Rearend 5 07-11-2010 08:15 PM
Ford 9 inch w/ 3.50 gears kleen56 Transmission - Rearend 6 12-30-2008 10:45 AM
9 inch noise cdiedrick Transmission - Rearend 15 10-09-2005 08:25 PM
Ford 9 inch rear end... whinning noise??? bg Transmission - Rearend 5 09-28-2005 01:03 PM
