Make a long story short, I built my own housing to put a Ford 9 in a 1999 Camaro SS. The car is a stick and the stock rear was making noise, so after two gear changes in the stock 7.5 and all them making noise I decided to build a 9. Everything turned out real nice except now the 9 is making noise. I started with Richmond Excels, which I know the reputation Richmonds have for making noise. Of course they made noise as low 10 mph. So, I bought a set of Yukons. I have a set in the 8.5 10 bolt in my truck and they are silent. Anyway they are 1000 times better than the Richmonds but I still have a small whine on acel and decel. I started out with the same .019 pinion shim I had with the Richmonds and the pattern was too deep. So I started to bring the pinion out. I went to .021 all I had was a .010 and a .011 to add together, back lash at .006. It still looked too deep to me but I was out of shims and the next jump I could make would be .025 and it was to far out. I loaded up the center section and took it to a local machine shop. Jimmy Mattingly’s Machine Shop. He builds pulling tractor engines and is a major Ford guy. Anyway Jimmy told me to open the backlash up and that my pinion shim looks OK. He gave me a couple more shims a .012 and a .014. This time I opened the lash up to about .008 and put the .010 and the .012 in to give me .022. It looked pretty good to me but it seemed like the drive side was staying too deep and the coast was coming out more than the drive. So I went on and tried .011 and .012 to give me .023 and it looked like the coast was too far out and the drive was good. I put it together with .022 and about .008 back lash and it has a small whine. I am thinking about just unbolting the pinion and replacing the .010 with the .011 put it back .023. I figure the lash will open up a little more but should still be in spec. looking for some opinions on where to go. I am about done with rear ends.... ain: I only put about 5 miles on the car for a test drive. I want to fix the noise so I don’t mess the gears up.
If you would like to see the 9 I built here is a link to it on LS1 tech
Many of the Yukon gears require more backlash than other gears. If this is a 3.70 gear then you may be having the same problem that I have had with them. I've had a few of the 3.70 Yukon 9 inch gears that had some noise in them.
Would you guys mind to take a look at these patterns? I have moved this thing around every which way and can not get a good pattern. It doesnt help now that they have been driven on. The coast side is staying heavy toe. I have opened the lash all the way up to .015 and cant hardly make it move. I can bring the coast up the tooth but the drive seems to get to one point then stop moving. Would you guys run any of these patterns? I am begining to wonder if its this aluminum Yukon case. I may try to set them up in the factory cast case just to see if it helps.
I spent the whole day moving that sucker every which way you could think. Changing pinion shims and back lash at least 50 times. I set it up in the old center section today and I think I have it. I have a pretty good pattern. The only problem is I have to change out the bearings on my trac loc to the smaller ones now. I had to put the ring gear on the open carrier that was the original to set it up.
No that I know that the gears can be set up I may try the aluminum center section one more time.
Well this is where I am going to run it. I took it all back apart, started over, and put it back together in the aluminum case. I think my problem before was that I wasnt tightening the caps tight enough before check my pattern. I put it back in the car and ran it on jack stand and I didnt hear a peep out of it. Before I could hear the noise running the car on jack stands. I havent drove it yet so we shall see...
Well I didn't do good if you know what I mean. I don't know what else to do to it. I am bound and determined to get a quiet gear in this car. Any recommendations? What about US Gear?
It just seems weird that the coast would not come off the toe with back lash changes.
I have more trouble with 9 inch gears than any others. I don't know why. I think I would have used the 3.70 gear instead of the 3.75 because the 3.70 is a more popular ratio and produced in higher numbers. They usually work harder to get things right on the high production gears than they do with the low production stuff.
Thats nice to know. Thats the reason I got rid of the 7.5 10 bolt. I couldnt get the gears to setup in them for anything and not make noise. Plus they are weak. I thought with the simpleness of setting up the 9 I could get this thing done and in the car. Looks like I might be buying another ring and pinion. Do you just mainly use Yukon? Should I try to find an original Ford ring and pinion.
Many of the "odd-er" in-between ratio Ford 9" gears(of which your 3.75 ratio set is, the 3.70 is the common set) are targeted primarily at circle track racing use, to taylor engine rpm at the end of a straight to exactly what they need...and so tend to be noisier because no one cares how loud they are in a racecar as long as they do the job and last the race or the season.
The difference between the 3.70 and 3.75 ratio is something you would never even feel on a street or strip application...if you ran each set back to back you would have an extremely hard time telling the difference by how the car acts...if you could even tell, because the difference is sooo small.
I think the common 3.70 set would be your best choice for a quiet gear.
Yea, I've just been using Yukon gears for the last few years. I do some Richmond or US Gear when there isn't a Yukon available, or if a customer brings his own gears. I've got to do a US Gear 3.31 for a 12 bolt soon, which is going to be interesting because they only made 200 of these. I've also got to do a Richmond 4.30 12 bolt gear soon, which is another low production gear. The 3.70 might be a better choice for you. I think you could probably get rid of the 3.75 if you wanted to. There are people who don't care about a little gear noise and would like a good deal on a set of barely used gears.
He told me that if my car was in his shop right now that he would put a Motive Performance gear in it. Orange box. He said that is the gear that they are having the best luck with right now. I asked about Yukon and he said those gears are made in India. So, I got off the phone with him and called Moser. I talked to a technician there that sets up a lot of their rear ends. I asked him the same questions and got the same answers. For an aftermarket gear buy the Motive performance gear. I asked him about U.S. Gear and this is what he said, "You did not hear this from me but they are out of business and if you buy a U.S. Gear ring and pinion right now they are made in China". He also went on to tell me that almost all the gear manufactures right now are sending out crap because they are cutting costs which means taking out some of the machining processes on the gears. He said that it’s a shame because this is what they have to deal with every day and that it is due to the bad economy. The American gear manufactures can’t afford to make the gears the way they used to just 5 or so years ago. If they did we would be pay $500 - $600 for a ring and pinion.
He also told me that if I could find an original Ford ring and Pinion, 3.70, that i would be good to go. I know where there are around 10 trucks that all have 9" rear ends in them. My local Pull-a-Part salvage yard. May head over there after work.
Did a couple of Mopar 8 3/4 rears about a year and a half back and both were Yukon and were made in Korea. Customer supplied the parts...bearings made in China. The gears looked fine but man, what cheezy looking bearings. Told him not to associate my name with them because all he was planning on doing was selling them. Whatever American companies are doing here...it's still got to be better than than what the Shineese are doing....
Last I knew Motive was made in Italy, and Yukon in Korea. Motive has been nice in my experience, and I've had no problem with Yukon but have not done Yukon in a 9" Ford, just Dana 60, 8.5" 10-bolt GM, and 8.8" Ford.
Last Strange/U.S. Gear I did was about 4 years ago,12-bolt Chevy car, came out good. Would be a shame if they are chinese now.
Worst gears ever in my experience were Zoom.
I had a set of Precision Gear for an 8.8" Ford give me a real challenge to get set-up a couple years ago, 4.10 ratio. Did not even come close to correct at the marked pinion depth.
I found 2 ford center sections at the junk yard today after work that had 3.70 gears in them. The 6 cyl trucks with manuals had 3.70's in them. I can get the whole center sections for $30 a piece. What do you guys think? I pulled the pinions out to count the teeth and they looked really good. Aren’t the OEM gears indexed or lined up a certain way from the factory? I came home and looked at the 3.00 gear that came out of my 9 and there are marks on the pinion and the ring gear like they lined them up from the factory.
They are only marked for tooth-to-tooth position if they are a non-hunting gear set, i.e. the same pinion teeth always contact the same corresponding ring teeth. An example would be a 36-9 tooth count for a 4.00 ratio gear set or 39-13 for a 3.00 ratio set(not actual #'s, just examples)
I have done hundreds of Yukon gear installs, and the appearance of the gears changes regularly. I think Yukon is just a reboxer, not a manufacturer, and contracts with vendors in multiple countries.
I got my center section this morning. Has Ford 3.70 gears in it. Came out of a 1969 F100, 300 6 cyl, 3 on the tree. I dont think its ever been messed with, the ribbing on these things make a good place for a mud dobbers nest. The bearings feel really good in it too, the other one I got, the bearings were shot.
I will clean this one up good enough to check the pattern and the back lash then pull the gears out of it. Then stick them in my housing and set them up right back like they were.
Had a few gear sets give me trouble setting them up with one taking 8 hours. Also have had several that showed a lousy pattern but was on the money with my old Pro Parts pinion setting tool. The first time that happened, I plugged the 3rd member into my car for a test run and it was still quiet after 200 miles. Did that with 3 different 3rd members. After that, I quit checking the pattern. That was over 20 years ago and so far, so good.
Wow, I hear people say to not use the depth tool becasue of machining differences from case to case, and that the pattern is the only way to really do it. Who knows....
I'm completely opposite of that. I got rid of my pinion depth tool because it's my opinion that the pattern is the only thing that matters. I had to reset the pinion depth every time I used the pinion depth tool, so I quit using it completely.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
