Originally Posted by Ford Junkie
Thanks guys that's what I needed to know. Now to figure out pinoin bearing sizes and I'm good to go.
Thanks again,
Tony
If you give me the BOM number off the Dana 70 I can tell you which inner pinion brg you have. It is located either on the tag thats bolted on the rear cover. Or if thats gone, on the rear of the pass side axle tube. Your looking for a 6 Digit number that starts with a 6.
Also for your Dana 70 you might look at a Spicer gear set as a option also.
