Z Frame Plans - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2014, 10:40 PM
31fordcoupe's Avatar
Last journal entry: Gunked up 454 water jacket
Z Frame Plans
Hey gents,
I am going to try and fab up my first frame for a 1939 Chevy Truck that I currently have (under the watchful eye of a good friend of mine). Right now the body is sitting on a 1983 S-10 frame (yuck) and I want to go old school with the suspension and Z the frame for a nice slung low look. My questions are these:
1. Anyone know where I can purchase some plans for a Z'd frame with a back half set up?
2. Instead of using a leaf spring up front with a 2" drop axle, I wanted to use a couple of QA1 coil overs up front with a 2" or 4" drop axle. Is something like this doable and if so, where can I find a set of plans to accomplish this? Is it better just to stick with a single leaf spring set up in the front?
3. Finally, I would like to have some modern disc brakes on the front with either a small Ford or small Chevy bolt pattern. What is the best (and cheapest) way to accomplish this using a 2" or 4" drop axle?
I would like to part this suspension together instead of buying an already made suspension, just because I would like to save money and part of it is the thrill of finding parts to make this work.
So basically I need a parts list and a set of plans for this frame and suspension. Anyone know where I can find a set of plans for this?
I would also like to use 2x3 frame rails (3/16 wall). I am putting a big block Chevy in this truck so if someone thinks I need to go heavier on the wall thickness or to a 2x4 set up please let me know. I am just trying to keep weight down where I can.
Thanks much in advance. Pic of the truck is attached.
Brent
Name:	39 chevy.jpg
Old 01-06-2014, 07:34 AM
Wiki Edits: 27
why cut this one up ? ?
Hot Rod How-To Books -- Hotrodders.com
Building A Homemade C-cab !!!
start with some 2 X 4's and mock it up , draw it on the floor and start cutting.
there are lots of disc brake kits for old ford and chevy I beam axles.
Creating NEW t-bucket frame plans - Need TONS of info, plans & measurements - HELP! lowROLLERchevy Hotrodding Basics 121 08-30-2011 06:31 AM
'23 t bucket frame plans??? dorksrock Hotrodding Basics 14 07-19-2009 07:28 PM
t bucket frame plans jcdiverdn Introduce Yourself 1 09-07-2007 06:24 AM
Frame Plans TUFFET1 Introduce Yourself 1 12-11-2005 08:55 PM
28-38 Frame Plans RATFINK General Rodding Tech 4 10-29-2005 04:03 PM
