Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Z06 Wheels on 64 Impala?
Old 08-12-2004, 10:37 PM
Pinto_Guy Pinto_Guy is offline
The fronts should not be too bad but the rears will be a bit inset I think. See if there is someone around that will let you try to fit one on your car.
I have a set on a Pinto and it required lots of cutting. I have a Jag rear end so I did not worry about hitting any suspension stuff. You will have to look at your rear control arms for tire clearance.
