Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Z06 Wheels on 64 Impala?
Old 08-13-2004, 07:04 AM
Uber's Avatar
Uber Uber is offline
Originally posted by Pinto_Guy
The fronts should not be too bad but the rears will be a bit inset I think. See if there is someone around that will let you try to fit one on your car.
I have a set on a Pinto and it required lots of cutting. I have a Jag rear end so I did not worry about hitting any suspension stuff. You will have to look at your rear control arms for tire clearance.
Yeah, it seems like I'm going to have to find a set locally to test fit them.
BTW, the wheels look sick on your pinto
