z28 305 boy - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2009, 03:38 PM
z28 305 boy
I have a305 an 400block I like to know can put my 305 head's an intake on the 400block
Old 12-18-2009, 04:06 PM
Hippie's Avatar
Last journal entry: HEI comparison.
It can be done, you'll have to drill steam holes in the 305 heads, it will raise the compression considerably and the heads and intake will be quite restrictive for the 400. If you just need to do it to make the car run and can afford the Premium fuel it will need it will work but if you're expecting the 400 to make any HP I don't recommend it. It will probably hit a wall about 4000 RPM, the off idle response will be great though. That's just my $.02 though.
Old 12-18-2009, 07:16 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Once again I am suggesting the forum search box be placed near the top of the page so more people see it and use it. This is another one of those questions that has been asked more times than I care to think of...
Old 12-19-2009, 06:16 AM
70455's Avatar
They wouldn't flow enough air to make it worth it.
Old 12-19-2009, 01:50 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
ive read a ton of 305 head on 350's but none on a 400
i certainly wouldn't put those heads on the 400 it wont make any power, even if you put the 416's and put the larger valves in them it still wont make good power, i'd go with a set of aftermarket iron heads, some may tell you to put vortecs on it but i dont even like vortecs on a 400, i barely like them on a 383, but on a 350 street motor they work great
Old 12-19-2009, 07:10 PM
Blazin72's Avatar
Wiki Edits: 19
What's the difference? Its still the same issue either way. And yes this question has been asked plenty of times on here.
Old 12-19-2009, 07:19 PM
fast68's Avatar
likes chevy trucks & boobies
because a 400 has bigger pistons and is a bigger engine than even a 350 and it will be suffocated alot more than a 350 would be even, with said heads on it,
the heads would at the very least needs tons of porting and pocketing and such done, and also bigger valves
and plus the steam holes drilled
i mean if you want to spend so much cash on them and then still not know for sure how it will do without actually trying them then go for it.
i would probably at least try to score some good used iron eagles or something first though, should be able to find such a thing on craigslist or somewhere for a few hundred at the most and have wayyyyy better flowing heads,
for a 400 that is..
ive run 4416 and such 305 heads on many 350 engines in the past but i just dont see myself ever wanting to try them on a 400.
its just different.,.
each has their own opinion though..
good luck!
Old 12-19-2009, 08:27 PM
Hippie's Avatar
Back in the 80's Car Craft, IIRC, put a 400 shortblock in a 3rd Gen Camaro with the stock 305 heads and TPI on top of it. It was a screamer from an idle to about 3500 and then fell on it's face. With headers and some other work they were able to get 4500 out of it but power still fell off severely at 4000.
305cid/372hp who said it couldnt be done King Kong Engine 41 11-11-2008 03:41 PM
dirt track 305 groomer Engine 12 04-20-2008 02:46 AM
Z28 with blown 305 X_Styx_X Engine 5 04-02-2008 12:23 PM
mild performance out of a 305 77formula Engine 4 10-23-2006 08:57 AM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
