Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - zero decking block
  #18 (permalink)
Old 09-23-2010, 12:45 AM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Originally Posted by CNC BLOCKS NE
If you go back and reread your advise its pretty lame as you should never bore any block off an unsquared deck thats just plain common sence.
I don't know how you bore your blocks, but you're making noises like you register off the decks. I haven't seen that done in a couple of decades. The block is set up to register off the main bearing bore and the block can be thusly bored without ever touching the decks with a cutting tool. Then the customer can pick up the block, take it home and proceed to find the piston deck heights with simple tools. Then the block goes back to the machine shop to be cut to square on the decks.
Of course the shop can do all this for the customer. I never said they couldn't. But there is more than one way to achieve the end result. Your way is not the only way and I wish you'd get over yourself.
