Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - zero decking block
  #24 (permalink)
Old 09-23-2010, 03:55 PM
CNC BLOCKS NE CNC BLOCKS NE is offline
Originally Posted by lmsport
Does that price include measuring the stroke on 4 throws on a used, reground crank? I'm not sure it was index ground or stroke corrected.
---And I have 8 rods, 2 are Oliver and 2 Carrillo and 4 Manley. They are all supposed to be 6".
---And I have 8 pistons, 2 are SRP and 6 are JE.
---Its already been balanced, but I want the deck height to be 0.000, +0.000, -0.001
We have a gauge for checkeing the stroke which takes about 2 minutes or less to check.
We have a fixture for checking rod lenth as well.
CH is not the hard to check either.
With all those mismatched parts looks like you have been blowing up some engines. And I can see why
Sometimes its hard to make chicken soup out of chicken ****.
We don't use reground cranks in our performance builds!! Or missed matched rods or pistons.
No matter what you going to dek the block to the longest rod and highest CH
If you using JE pistons and they have a 1.250 CH you may want to check the CH of the SRP pistons most of those are 1.260 CH
Have fun!!!
