Zinc based oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2017, 06:36 AM
Forty2door's Avatar
Zinc based oil
I used zinc based oil in the startup of my Chevy build to break in the flat tappet cam. After break in, do I need to continue using the zinc based oil for all my oil changes? Thanks for your advice.
Old 03-20-2017, 07:39 AM
In 1986, my 1962 Chevrolet 327/300 was started and has run for more than 60k miles on Valvoline 10w-30 All Season from Wal Mart. It has a GM "151" L79 camshaft and Pioneer RV943x valve springs, that were set up with 130 lb seat at 1.700" and 304 lb open pressure at 1.253" (.447" valve lift) and coil bind is 1.15". Those springs will lose about 10% load in the first 500 miles. No machine work necessary.
Your engine may be different.
The Following User Says Thank You to MouseFink For This Useful Post:
Forty2door (03-20-2017)
Old 03-20-2017, 07:56 AM
I really wish people would stop recommending the diesel oils. The EPA has cracked down on diesel oils, new diesels have equipment that is sensitive to the amount of ZDDP in the oils, just like our gasoline hotrod engines.
Your best bet, is to use a proven product that is DESIGNED for the purpose. Saving a dollar or 2 a quart sounds awesome untill your engine craps the bed, and the cam manufacturer says "what oil did you use?"
To me, its not worth it.
On a personal note, Ive never been sold by the 'dump in this concentrate' method. Better than nothing? For sure! But, even if you mix it in 2 quarts of the oil during your change; how long does it have to run before its mixed homogeneously throughout the entire 5+ quarts? What about extended downtime? If I park my car for a month, will it settle out and need to be re-mixed into the oil?
For those reasons, I recommend either Brad Penn or (Joe Gibbs) Driven oils, that are designed to do the job.
Just my two cents. Maybe CStraub will chime in; as a custom cam designer, he probably sees more of this in a week, than I will in a lifetime.
The Following 5 Users Say Thank You to AutoGear For This Useful Post:
bubba1955 (03-21-2017), Forty2door (03-20-2017), lmsport (03-20-2017), Richiehd (03-20-2017), RWENUTS (03-20-2017)
Old 03-20-2017, 08:36 AM
I agree. Diesel oils belong in Diesels and only some of those need to go into diesels. Ford has stated with the latest formula from the API that your warranty is voided if you use the new oil. Here is the tech bulletin:
CK-4 Diesel Update
Recently Diesel engine oils changed from the decade old CJ-4 formulation to the new CK-4 formulation. While intended to be an upgrade, the new CK-4 formulation has been met with resistance and even an outright “do not use” warning from Ford Motor Co.
The new CK-4 specification went into effect in December of 2016, and just before the launch of this new specification, Ford Motor Company issued a service bulletin stating that Ford 6.7 Litre diesel engines should not use the new CK-4 oil. In fact, Ford issued a new oil specification closely aligned with the previous CJ-4 specification and called for the use CJ-4 oils meeting the new Ford specification for their 6.7 Litre diesel engines.
The reason for all of this? Ford identified wear issues as the reason for abandoning the new CK-4 oil specification.
What is the underlying issue with the CK-4 oil? Previous API diesel oil specifications, like the decade old CJ-4 specification, had to pass the ASTM Sequence IIIG valve train wear and oxidation test. This is no longer true of the new CK-4 specification. The Sequence IIIG test measures flat tappet cam and lifter wear as well as other parameters. The significance to both Ford and other users of diesel engine oils is directly tied to the absence of the Sequence IIIG test.
Diesel engine oils have historically contained higher levels of the anti-wear additive ZDDP. With more oil marketers wishing to supply “universal” oils that meet both API SN requirements for gasoline engines as well as API CK-4 requirements for diesel engines, the levels of ZDDP have dropped in some CK-4 oils. Without the Sequence IIIG flat tappet cam wear test, it appears some of these lower ZDDP diesel oils are causing increased wear in Diesel engines. This should be a word of caution for all users of diesel engine oil – regardless if you own a 6.7 Ford or not.
The Following 3 Users Say Thank You to StraubTech For This Useful Post:
AutoGear (03-20-2017), Forty2door (03-20-2017), Richiehd (03-20-2017)
Old 03-20-2017, 08:38 AM
I am curious about EDM lifter oiling. Flat tappet lifters so equipped have a oil hole drilled in the face of the lifter, offset to the lifter centerline. Those may or may not be beneficial if the valve spring pressure is more than 130 lb / 320 lb open. Crower offers mechanical lifters with the optional EDM oil hole. Those look like the ones I will use with a solid lifter cam the next time the opportunity arises.
I wonder how long it would take for the little EDM hole to stop up with debris in the oil or stop up due to normal wear.
Old 03-20-2017, 08:48 AM
I had a tappet engineer in 2006 tell me that at that time if the stars were aligned properly and you crossed your fingers that at flat tapped cam and lifter had the life expectancy of 10 to 15K miles before it failed. This was due to several factors.
I don't have anyone calling me with failed rollers wanting to go to flat tappet. I do have several a year with failed flat tappets now wanting to go roller.
The Following User Says Thank You to StraubTech For This Useful Post:
Old 03-20-2017, 09:38 AM
johnsongrass1's Avatar
Race it, Don't rice it!
As an engineer my self I want to see real facts....Not just one that are made up based on what the internet says.
Some issues I have are:
Can all the FT cams in existence currently from all forms of racing and street are doomed to fail in very short order? really? How do you explain the millions that haven't yet? How many FT cams fail because of improper set up or spring set up or other mechanical set up issues blamed on bad oils cause humans like having a reason to blame something on something else. How many FT cams are running around with no issues but never get mentioned?
If FT's are doomed and truck loads of bad cams are being returned for failure why hasn't the free market responded with ceasing production? Why hasn't the price or RC come WAY down with the flood of RC's because FT fail near every time?
Oil technology is changing rapidly. By the time news hits the market and it publicized the tech is already old in my opinion. Oil has always been a factor in engine life expectancy so I would have to assume it still is. If a cam failes because someone didn't use an oil proper for the design is that really the cams fault of user error instead?
I have a lot of other questions prolly without easy answers as well. I don't doubt RC's are superior in most ways except pricing but I thing it's a little narrow minded to say all FT cams are doomed from the start when the facts or production and profit support the FT still lives on. I'm just trying to fair and objectionable as some one that has ran both for years and the only failure I've had was because of poor manufacturing and tolerances.
Flame on...I can take it.
How many
The Following 3 Users Say Thank You to johnsongrass1 For This Useful Post:
4 Jaw Chuck (03-20-2017), Forty2door (03-20-2017), hcompton (03-20-2017)
Old 03-20-2017, 09:46 AM
Only works on solids. Yes it works, Ford did this on the original Indy engine just for this reason.
Probably half this problem is from misaligned lifter bores on GM blocks. They don't have to be off much to cause unusual lobe and tappet wear on flat tappet engines; where rollers are much more tolerant of these slight production misalignments of lifter center line to camshaft centerline.
Bogie
The Following User Says Thank You to BogiesAnnex1 For This Useful Post:
Old 03-20-2017, 10:21 AM
Forty2door's Avatar
Zinc based oil
I sincerely thank all of you for your advice. That's why I love this site! I guess what I'm asking is do I need to continue using zinc based oil in my future oil changes.
Old 03-20-2017, 10:30 AM
OProbably 80% of FT cam failures is due to excessive valve spring pressure.
I have never had a FT cam failure. I have always used FT camshafts that required valve springs with less than 125 lb seat / 320 lb open pressure. Chevy engineers recognized the problem as far back as 1962 and did not offer a valve springs for Chevrolet engines with more than 120 lb closed / 320 lb open pressure and the cars had a 50k mile drive line warranty. That includes the Chevrolet L88 engine option. Cam failures then were and still are due to "More's Law"
The reason is that Motor oils have less ZDDP today compared to 1960 -1970, when high performance engines with FT camshafts were offered to the public by automakers. The EPA forced automakers to eliminate the camshaft oil hole in the rod cap in 1972, which caused camshaft failures in 1973-1985. The EPA said the oil spray on the cam lobes and cylinder walls caused excessive pollution. Automakers reduced valve spring pressures on the FT camshafts but the final solution to the problem was roller camshafts.
Old 03-20-2017, 10:50 AM
Forty2door's Avatar
Zinc based oil
Thanks HC. That's exactly what I was looking for.
Old 03-20-2017, 11:23 AM
This is what I use and sell, this is basically the same as the old Kendall GT1 oil made before Conoco bought the Kendall brand name.
https://www.summitracing.com/parts/b...4-12/overview/
Brad Penn Grade 1 motor oil is desirable for their anti-wear additives, making them highly suitable for flat tappet camshaft engines. These high-quality race lubricants are 100 percent made in the USA for racers, engine builders, and enthusiasts. Brad Penn Grade 1 motor oils have a unique base oil that causes them to cling to your engine's parts, minimizing wear during high-torque, high-stress competition. They contain highly effective detergent and dispersant additives to keep your engine clean and running at the peak of performance. These motor oils are available in synthetic blends and straight grades. They are designed for the higher lubrication of competition engines with superior alcohol separation to ensure continual lubricating of the engine.
Old 03-20-2017, 12:07 PM
Most part-timers have no idea what valve spring pressure their FT camshaft assembly has. That was not a priority when their grocery getter engine was assembled.
If the car does not have a catalytic converter, the best thing those individuals can do is use Brad Penn Racing oil or Valvoline VR1 Off Road oil at $5.50 per quart with the maximum allowed ZDDP additive.
Old 03-20-2017, 02:49 PM
There are about 50 different chemical blends to put a Zinc additive in an oil. Now which blend is best for your application. It's not as easy as just adding Zinc.
Also we were told unless something is blended at the refinery with the oil that any additive that is added to the oil will not mix with the oil. It will stay seperrated.
Old 03-20-2017, 09:58 PM
4 Jaw Chuck's Avatar
I've got a mid eighties built 289 with a Comp 280H cam and double Comp springs torn down in my garage right now, has had every plain supermarket brand in it since it was built...zinc or not.
Not a single problem with its lobes or its lifters, I call BS on cam failures caused by ZDDP. If you ask me this is an offshore cam/blank supplier issue not an oil problem.
The same cam is going back in along with the lifters, not even concerned.
— Han Solo
zinc in oil bullheimer General Rodding Tech 6 07-25-2015 07:31 AM
Is Diesel Oil Still high in Zinc? TGBTG7701 Hotrodding Basics 16 11-29-2013 08:53 PM
Zinc oil OMARS67 Hotrodding Basics 9 03-23-2012 08:11 PM
Engine oil.....ZINC solidaxel Engine 4 06-29-2007 08:42 PM
Oil additives.....was it zinc that was removed? TurboS10 Engine 11 10-16-2004 07:07 PM
