Zinc body filler to patch rust?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2007, 06:42 PM
37year old kid's Avatar
Biggest tool in the box!
Last journal entry: Super Stock
I just read an article about a new process that involves spraying a special Zinc Filler on rusted body parts (the article guinea pig was a 65 El Camino rear lower window channel).
They first sandblast the affected area until good metal is found. Then they spray this Zinc stuff into the area until filled. Filing and sanding and reapplying until all low spots are filled and ready for paint.
Has anybody out there used or know anybody who has done this?
I have my 70 Chevelle and the lower window channel is rusted. This seems like a cheaper and faster fix than replacing the panel. Anybody?
Old 02-14-2007, 06:47 PM
poncho62's Avatar
Wiki Edits: 5
Isn't galvanized metal zinc coated?....And it's tough getting paint to stick to it.
Old 02-14-2007, 07:18 PM
I'll have to re-read the article (again) but it IS a type of zinc. I thought the same thing. Zinc is hard to get anything to stick to. I attempted to weld some corrugated sheets together at my old job and besides wearing breathing protection, the stuff is hard to weld to mild steel too.
It's sprayed much like a spray on bedliner with a special type of gun and seems to be worked over like lead. Weird stuff.
Old 02-16-2007, 02:02 AM
Is it Rustbusters?
www.rustbusters.com
video at http://www.rustbustersllc.com/rustbustwebmovie.asf
Old 02-16-2007, 05:54 PM
Originally Posted by jimfulco
Looked the same to me, but how do you paint galvanized metal?
Old 02-16-2007, 08:41 PM
Race The Truck
Last journal entry: Son's Truck
It has a oil film to it. They make a etching cleaner you use before painting.
I welded a ton of that galvanized stuff safety equipment heck we had fans and the old welder fix drink milk.
Craig
Old 02-17-2007, 03:35 PM
gator412's Avatar
1955 2nd series Chevy Pick Up
Last journal entry: Body work and U bolts
You have to wipe it down with a mild acid to etch the zinc coating so the paint will stick. Be sure to rinse the acid off with clean water and let it dry completely.
Plastic filler tips. MARTINSR Body - Exterior 14 03-03-2009 06:11 PM
Alternative Metal Body Filler bg Body - Exterior 3 06-14-2006 03:56 PM
Body Filler Issues Oddball Body - Exterior 19 05-10-2006 05:20 AM
body filler esahlin Body - Exterior 18 02-12-2006 03:59 PM
Rust on interior of body... joeford Interior 7 08-09-2005 04:41 PM
