Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Zinc for roller cam engine?
  #25 (permalink)
Old 10-26-2012, 04:49 PM
painted jester's Avatar
painted jester painted jester is offline
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Originally Posted by E.Furgal View Post
rollerized lifer cams or rollerized cams.. that ran in roller cam bearings?
Are you asking a question you need an answer for? Because the difference is very simple ! (I never heard of rollerized cams!) I have used rollerized cam bearings and the last ones I installed the block machining for it was $700.00! A little expensive for most people and not needed for most engines the lead Babbitt bearings work well enough !unless you want extended life for race type abused engines or industrial engines that run 24 hrs. a day 365 days a year ! When you say "roller cam' its understood by most engine builders and cam co.'s that your talking about a cam ground and designed for roller lifters! Usually an engine builder uses rollerized cam bearings after many Babbitt bearing failures! Or is running them to head them off On very expensive engines!
I hope this answers your question
Jester
