Zinc for roller cam engine?
I have heard differing opinions on this question and wanted to ask the experts out there. Also, what weight of oil would you suggest?
ZDDP is what its commonly called. zinc is just one part of it. Motorcycle oils still have zddp same goes for rotella and a few of the desiel oils. They are recommended for cam break in.
Normal car oil no longer has zddp in it. Not sure about royal purple and the performace synthetics. |
I have used Rotella in the past, but did not have a roller cam. Was not sure if there is a difference when running a roller.
ZDDP is an extreme pressure lubricant that is necessary to prevent scuffing when using a flat tappet hydraulic or flat tappet solid lifter camshaft. No such extreme pressure lubricant is needed with roller tappets. Just clean off the preservative oil that the factory puts on them to prevent corrosion, dip them in off-the-shelf engine oil, install 'em and run 'em.
Here's a tutorial showing the procedures to prevent "fraggin" a flat tappet camshaft.... http://www.crankshaftcoalition.com/w...ips_and_tricks In today's world, it makes little sense to jump through all the hoops to use flat tappets, when for just a little more dough, you can install rollers and forget about it. There may be better deals around, but Competition Products sells a set of Howards retrofit hydraulic roller lifters and a roller cam for about $600. Add a Howards composite distributor gear for about $100 and you're done. No worries, no headaches and much better performance due to the increased "area under curve" of the roller cam. |
| The Following User Says Thank You to oldbogie For This Useful Post: | ||
techinspector1 (10-24-2012) | ||
Like Tech said zddp is an extreme pressure lubricant , the main reason its content has been reduced or removed is it ruins cat. convertors! But engines have other areas that need zddp like the fuel pump actuating rod that rides on the cam on older engines and timing chains any where there is metal to metal contact that has friction!! If your not running a cat. it wont hurt a thing to add zddp for an extra precaution in high friction areas of any engine especially air cooled, and at the valve tip if there is any sliding of the roller rocker or at the push rod ends that make contact with the lifter and rocker arm Etc!!
Jester |
| The Following User Says Thank You to painted jester For This Useful Post: | ||
Thanks bogie and jester, good points.
even with fully rollerized engines.. things they don't tell you 1) the new car engines have alum heads with selflubing valveguides.. of a bronze alloy of some type 2)most if not all don't use a ball and socket set up on the rockers anymore.. 3) the rockers have hardened ball sockets for the pushrod to ride on in the rocker. and hardened tip push rods... 4) no guide plates for the pushrods.. why does it matter.. everything above needs the zinc to not wear at the metal to metal pressure points... an issue new cars and their powerplants don't have to worry about.. but YOU might... as they are metal to metal points never mind a cam and lifter... why might you say there isn't an issue in the bearing area.. well because that is not metal to metal.. the crank and rods float on a film of oil.. when they do become metal to metal bad juju.. piston pins, the piston bore is the bearing.. and on most new engines they spray oil on the back of the piston face... to cool the piston.. and in doing so.. lube the piston wristpin and bore.. the zinc removal isn't just about cams lobes.. it's just the highest stressed area and the spot that failure shows it's face first.. |
Not necessary related to a roller cam and zink,but a common mistake guys make it when priming oil system they over prime it washing away the break-in lube.The correct way to do it is the 1/2 drill motor will slow down once while filling the oil pump and once again while filling the oil galleries.You should stop priming at that point.
There are other points in your new engine that need the anti scuff anti wear properties of zinc and moly di sulfide
oil additives, besides the camshaft. I use and recomend this stuff. Its got both in it. helps the new engine break in properly and gives you the metal on metal anti frictrion,,, anti wear protection needed for long engine life. Including flat tappet cam and lifters. MOLYSLIP E Molyslip Canada Inc. :: Molybdenum Lubricants, Performance Lubricants, Copaslip Anti-Seize, EP2 Grease, Wear Reducing Lubricants, Oil Additive i use the GM EOS too. Last edited by F-BIRD'88; 10-24-2012 at 02:26 PM. |
So should I just use Rotella or similar to be safe?
The new Rotella T oil still have Zinc in it. Just not as much.
It's still very good oil. They just adjusted the anti-wear formulation. There is a lot more to it than just the Zinc. Its still one of the best oils you can buy. There are still lots and lots of speciality "racing" oils that still have all the zinc you will ever need. It is the over the counter-off the shelf- parts store passenger car motor oil that got the reduction in Zinc. |
telling people to use big rig oil was good info years ago.. and may still be up in canada.. but not in the land of the EPA |
Rotella covers about 25 oils all for different types of engines. They have oil for trucks older than 2010. They also have the new stuff and off road for equipment.
Zddp does not trash your cats it shortens the life of them in engines burning oil. Zddp and cats have been mated together for 30 years its just better for the cats if its not in there. Your car will still be just fine with it. Your cats will still go for 100k miles if the engine runs clean. Yep the cam is important but not all of your worries when it comes to breakin. Alot of other parts really need the additives. Roller or not. It wouldnt hurt your roller cam either since it is still under alot of stress and friction. But the cam gets tons of oil other parts of the engine dont see pressurised oil. These parts still need some protections. Bearings are made from a molly and zinc compond. Ever wonder what you were rubbing off everytime you ran your thumb across a new bearing. I am stunned at the crap ppl give flat tappet cams. 99% of the problem is ppl trying to find more "area under the curve". Cam manufactures have an issue with new cams because there not for new engines. All the best designs have pattens on then but the cam makers still put out new cams every year. How many of the new grinds do you think are better? You can only slice up 360 so many ways. Before you start putting out crap. Eos is good as well. Its out there on shelves for a reason. |
Okay, thanks for all of the great information. All I am running is a mild pretty much stock Chevy small block (vortec) with a roller cam...headers with glass packs and that is it. It is a new engine so I want to make sure it is protected well. Sounds like I just need to run some Rotella or similar.
Thanks! |
| Engine break in w/ roller cam? | chucksrt | Engine | 4 | 09-04-2011 02:32 PM |
| Cam break-in and zinc | Frisco | Engine | 34 | 03-13-2007 08:22 PM |
| First engine build - would a roller cam be a better choice? | surfshark | Engine | 4 | 05-28-2006 06:02 PM |
| new engine, roller cam break in ?? | x007 | Engine | 9 | 02-22-2005 08:18 AM |
| how to tell if my engine has a stock roller cam? | Gino Fultano | Engine | 4 | 08-10-2003 10:31 PM |
