Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Z'ing a bagged c10 frame ride height?
Old 01-08-2013, 10:29 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
If you Z the frame... It will change a lot of things.. The motor will sit higher,The rad will be higher,Bumper brackets will be higher,, A lot of things to look at when you start to Z one... Inner fenders will have to be lifted as well.. Think about this... If you Z the front This means your lowering the cab on back, And The front will remain the same... Now you have to lower the whole front Cap to meet up with the cab again...Putting everything under the hood higher... It can be done... But just keep all this in mind.. You say it is bagged.. Doesn't it sit low enough aired down ???
Keep in mind there is a lot of parts out there to get it down in the grass.. Without Z-ing the frame..
