Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Z'ing a bagged c10 frame ride height?
Old 01-09-2013, 10:26 AM
MARTINSR MARTINSR is offline
With the points brought up I am thinking your may be better off to simply channel the body and bed over the frame. The only difference is you loose some head room, but those are pretty tall cabs and it shouldn't be an issue.
Look at it this way, the points Randy brought up about all the mods you have to make to rad support, inner fenders and all that still have to be done if you channel it, but channeling the cab and bed is a lot less engineering challenging than Zing the frame so maybe it would be a better call to "swap" the work of zing the frame to channeling the cab and bed?
Just an idea thrown out there.
