I'll stick with my clear powder coat. That sounds too ocmplicated and easy to waste $$.
Powder Coating is a surface coating
The Zoop Seal product does not leave a surface coating, if it does it's invisable to the naked eye. If you polished your part before applying the sealer, then it will look the same after you've sealed it. Most folks that spend big bucks on polished billet parts, do so because they like the look. Many spend hours polishing to keep their parts looking new, I can't say how long this stuff will last, the manufacture claims three years, but it looks good now and the product is easy to use if you follow the advice in my original post. I remember back in '61 I owned a 57 Chevy and I had alumimum Corvette valve covers on the little 283. I cleaned em up real good and sprayed on some clear lacquer, never had to clean them again. Lots of stuff out there today to keep your polished parts lookin' good, then there's the spray-on stuff, lacquer, Krylon, etc.
zoop sounds a lot like a two component epoxy with a finishing paste, I used a product very much like it to get a mirror finish on pianos ( I had a furniture shop a few years back).was it supposed to be brushed on?or was that because of the no spray gun thing?
the only problem I forsee ,is that the stuff is almost impossible to remove if you mess up.even the commercial furniture strippers couldn't remove it, and they made circa look like mothers milk. I know it will only last a few years ,but I need to do something with my solid aluminum valve covers and air filter , as every time they get damp, they get messed up. I might be better off just using clearcoat, at least you can strip it off. mike |
Powder coating has all the benefits and none of the negatives. Tough, smooth, chemical proof, temperature resistant, very clear, very strong bond, strips easily with most strippers, and relatively inexpensive.
Powdercoating may be inexpensive where you are but here it ain't cheap at all. I did my truck aluminum wheels and sprayed them with the spray from Eastwood. I built it up to 3 coats a few minutes apart per their instructions and they look pretty good. My next project is an old diamondplate tool box for the back. I'm really dreading the polishing that must happen before the finish coats go on.
Zoop Seal can be removed
According to the instructions a thin application of the sealer is what you want. It's applied not with a brush but toweletts that are included with the kit. A brush would apply it too thick. The "Final Finish" doesn't seem to be abrasive and the instructions say it's not. After the product is dry and before using the "Final Finish" you can see there is some type of film on the surface, like a rainbow haze is the best way to describe it. The "Final Finish" removes all that and the piece looks freshly polished. If the product was applied too heavely, then several applications of the "Final Sealer" will be required. The instruction say that if the product is to be removed for any reason then ordinary billet polish will remove it. They also caution against using any type of caustic cleaner as this will remove it as well.
crystallized zoop seal
Hello all.
I bought a kit of zoop seal to protect polished aluminum, as I've read in some posts here. The part B of the zoop seal kit appears to be crystallized. I've been shaking it for a long time, but the grains have not disappeared. Is that normal? I don't want to mix part A with part B until being sure that the product has not expired or it has something wrong. Any experience? |
I've used Zoops Seal on my blower motor that has a lot of polished aluminum. Its been two years since ,and all I have to do is use a little spray wax detailer,that I use on the body, to remove any dust and grime that may get on the motor.I've got a new set of Centerline Wheels coming friday and plan on Zooping them before mounting. Very happy with the product results! MAZINGERZECA all my parts were a liquid ,I would return it to were you got it or call Zoops for advice.
Shane |
Since searches are so common & valuable I thought I'd share this current info. I used a product called Everbrite on my polished aluminum valve covers with excellent results. It applies easily, doesn't run, reasonably priced, & best of all it works . I have no affilitation with them, just a good product.
www.everbritecoatings.com Fred (acr) |
Does Everbrite work on unpolished, as cast aluminum? I'm thinking of using something to seal the as cast finish on all the aluminum pieces on my blower engine...
Yes, it is a clear coating that will cover most anything except rubber, & some vinyls & plastic. On my finned aluminum valve covers the un-polished areas between the fins are free from any tarnish or stains. It can be brushed or sprayed on, but if you apply with a brush you have to be careful not to "over brush" it as I almost did. And if you goof up it can be stripped off with solvent & redone.
Go to their website & read about it, it has many uses. A couple of these are to rejuvenate old, faded signs & siding, including aluminum siding. It brings gloss back to the faded colors & protects from the elements. |
