Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ZZ 502 HR Cam Suggestions
Old 01-09-2013, 08:50 PM
BMFZZ502 BMFZZ502 is offline
I am need some advice on picking a new Hyd. Roller for the 502. This will be street driven and will have a 150 N20 plat system.
The engine is at the machine shop getting freshened up.
Block is being decked to zero
New Scat Forged Rods
GM Performance Aluminum Heads flat milled 0.030 to bump comp to 10:1 and pocket porting/valve job.
Honing Cylinders new bearings and new rings
Edlebrock Air Gap
850 DP Black Diamond Quick Fuel Carb.
Note: From what I have read I need to watch out for the lift because of the stock lifters??
Any Suggestions??
