Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ZZ 502 HR Cam Suggestions
Old 01-11-2013, 10:56 AM
35WINDOW's Avatar
35WINDOW 35WINDOW is online now
Last journal entry: Update on my Build-Lights
I think it all depends on how much hp/tq you are looking for-if those are the stock aluminum GM heads, they were made by Edelbrock (look at their part#60459-the GM head has a 2.25" valve in it, otherwise the same)-
If you are leaving the compression alone (?), and using the GM heads, I think you have a couple of choices:
1. Use the stock GM Cam
2. Use the Cam Edelbrock has designed for this Head (which will dictate new Lifters):
Performance Camshafts, Lifter Kits and Matching Valvetrain from Edelbrock - Cam Card Locator
3. depending on how serious you are, you could contact a custom cam designer (someone like Mike Jones):
HOME
4. buy an "off-the-shelf" cam (which can be hit or miss sometimes, depending on the skill of the selectee)-
I would certainly (at the very least) have the Springs checked (you will probably have to replace them)-
One thing leads to another, and pretty soon you are building a custom engine-watch out! Horsepower is addicting!
