ZZ3 Cam Timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2009, 12:05 AM
ZZ3 Cam Timing
Me and a buddy went through a ZZ3 engine that had been run hot! It messed the heads up so we replaced them with Trick Flow twisted wedge heads. Went thru engine, rings, pistons, etc, but kept stock roller cam and installed it with a edelbrock double roller timing chain set: QUESTION: We installed the cam in the straight up position with this chain, is this correct or should it be installed in advanced or retarded position? (The engine cranks and runs fine but with the feel and horsepower or a 4 cylinder) Thanks guys for your responses---
Old 02-22-2009, 12:46 AM
DoubleVision's Avatar
Being it`s profile is on the small side you wouldn`t likely notice any difference if it were set either way. Being it lacks power is likely going to be in the tune.
Old 02-22-2009, 12:53 AM
Thanks for the reply, even though it is a "smaller" cam grind, we did have problems with piston to valve clearance and had to disassemble engine and cut valve reliefs in the pistons to keep them from hitting. As for as tuning how bad off could we be?
Old 02-22-2009, 01:12 AM
Whats the base timing set at? is the vac advance connected to a ported or a manifold source? What shape is the tune up in? (condition of plug wires, etc.) You have checked it for vacuum leaks? What carb size? did you use a dual plane or single plane intake? What intake port size are the heads? are the valves adjusted correctly?
Old 02-23-2009, 11:51 AM
We actually done this engine around 8 years ago! Really been sitting up since then since it had no power. The heads were supposed to be the "*****" back then, turns out they really were! ($1200) Thanks for all the input, I will degree the cam and go from there, the original heads actually had holes melted in them from overheating, reason for replacing them, Thanks guys---
Have I somehow screwed my cam timing? Confused. v8hed Engine 13 08-17-2008 02:31 PM
Cam Timing reflog Engine 13 07-08-2008 10:00 AM
Ignition timing woes KNanthrup Engine 16 07-22-2007 09:18 PM
cam advance/retard & dizzy timing wayneair Engine 5 12-14-2005 07:50 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
