Roller cam engines don`t require a cam break in. I would run it on conventional oil for the first 500 miles, change it, and run it the normal 3000 miles. Afterwards you can switch to synthetic oil if you wish.
DV is correct.
A good tip for ring break-in is once you are out on the road is to lock the trans in low gear, then proceed to do a 10-cycle acceleration/coast down. Accelerate stoutly(3/4 throttle+) from a very slow roll up to 4500-5000 rpm, then off the gas and let the engine do the braking back down the rpm scale. 10 repetitions, this loads the rings against the cylinder walls to properly seat them. |
This is a copy of the page in the booklet that came with my Fastburn engine.
I had to post the larger image so you could read it. I also know that the current logic about break in of roller cammed engines does not follow this procedure to the letter, but it's better to be safe than sorry as far as Pace Performance is concerned.Vince |
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
| SBC Break in Procedure including Timing....??? | DarknessSpawned | Hotrodding Basics | 24 | 08-01-2009 06:25 PM |
| Break Bleeding procedure | Furytom | Suspension - Brakes - Steering | 11 | 05-22-2009 08:11 PM |
| Rebuilt Chev 350 Break in procedure | JD's camaro | Engine | 5 | 01-11-2008 08:32 AM |
| zz3 break in procedure | claust | Engine | 2 | 10-09-2006 11:17 PM |
| What is the best Engine Break in procedure and for How Long? | Houman SS '70 | Engine | 3 | 07-01-2005 03:22 PM |
