Yes I like that cam you chose too. I have 08-432-8 that was what AFR suggested I use. I wonder why they didn't chose a cam like the one you chose. The block that I have is a zz350 from gm brand new short block the block I'm sure isn't decked. I think the piston is going to be in the hole somewhat. I drive trucks so I am only home one week out of the month. I was going to keep the heads at 65cc and use a thinner head gasket but AFR recommend not to do that. They said mill the head. I told them what I had. I wonder why gm doesn't deck the block. They use a 0.051 head gasket. I was hoping I could bolt this together this weekend. I allready installed the camshaft and loctite the cam retainer in so comp probably won't return the camshaft.Will I be alright with a high quench I hate to have to disassemble the block to have it decked.
