ZZ4 Cam into a 350 vortec - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2008, 09:25 PM
I have a 1999 vortec 350. I'm wanting to swap a ZZ4 cam, with roller lifters, new springs and 1.5 roller rockers. Will this work? Any info would be appreciated.
Old 08-14-2008, 09:32 PM
While the cam itself will fit, and you probably already have roller lifters in your current engine (you can reuse them), the lift on that cam will exceed what the stock vortec heads can handle without something hitting, there were a couple posts about getting more lift without machining the heads, using some different seals and/or locks and retainers.
Old 08-14-2008, 10:06 PM
SSedan64's Avatar
With the correct springs, retainers, seals & locks many adds say you're able to clear .550" lift without machining. Here's a good article on the Vortecs>
http://www.nastyz28.com/forum/showthread.php?t=56505
Old 08-17-2008, 09:22 AM
Thanks for the replies to that question. My engine is in a 1999 Suburban. I'm planning on swapping out the cam with a ZZ4 cam. I also have another set of vortec heads with different springs and the 1.5 self aligning roller rockers. I'm wanting to get some more power out of my suburban while still able to get decent gas mileage. Would this be the way to go or is there a different swap that I could do?
Old 08-19-2008, 08:52 PM
Any chance the new cam would confuse the computer?
Old 08-20-2008, 01:24 AM
SSedan64's Avatar
Good point Jim. I'd call a few cam companies and ask about the max lift, duration & lobe seperation you can use with the stock computer.
ARE 305 and 350 VORTEC HEADS SAME badriand Engine 39 04-06-2011 08:40 AM
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Need Help FAST!!!!!!!!!! millertime85 Engine 14 06-25-2008 07:01 PM
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 07:45 AM
Stock 350 with bigger cam runs ****ty! help MotormanEN Hotrodding Basics 4 11-02-2004 09:10 AM
