ZZ4 cam for street motor??????'s
Recently I had to replace my 383 due to a broken chinese crank.I'm replacing the 383 with a 96 truck 350 vortec headed longblock.I have a practically brand new ZZ4 camshaft and was wondering if this would be a good addition to the 96 vortec motor.I have a set of vortec heads that have been modified for .525 lift camshaft.The GMPP catalog said that the ZZ4 cam was a good mild idling cam,that produces lowend torque and horsepower.The add also said that the cam was perfect for street cars and trucks.The motor is going in a 85 chevy truck thats mostly used for truck stuff.Just the normal stuff driving here and there,going to Lowes for plywood or 2x4's,hauling aload of mulch for the wifes flower beds,and occasionally towing a 16ft trailor with my diesel tractor and bushhog about 200 miles one way to the hunting camp.I have headers,performer vortec manifold,hei,and 600 holley carb.The trans is a turbo 350 and I'm running 373 gears.I'm fully aware that they make low torque and towing cams but brand new they run about $300 to $330 dollars.I already have the ZZ4 cam and if it want work I'll just go with the stock cam thats in the motor.=What is the compression on a stock 96 motor?Since the motor is no longer fi and computer controlled will I need to run 93 octane gas or will I be able to use a lower grade(this is with both cams stock and ZZ4) .I believe I will need different valve springs ,which ones will I need?If you have any info regarding this I would greatly appreciate it,I'm right at the point of putting the motor in.Thanks for the help!
cam
I have that zz4 cam in a 302 in my malibu wagon. The thing idles at 800 rpms or so with excellent vacuum.
IMO it would be perfect for what your doing. I am building a 383 for my 96 ext cab truck and that is the cam that is going in it. Keith |
Kstar,think you very much for the reply.Will I have to replace the valvesprings on the modified vortec heads that I have.They came fromScoggin Dickey already modified for the .525 lift,I'm assuming that with the ZZ4 roller that they would need changing out.Can you give me a recomendation for the correct springs?Thanks again!
Thanks for y'alls help its greatly appreciated.mupton
| Cam Selection and Dynamic CR | Arcuden | Engine | 10 | 03-23-2008 11:03 AM |
| I need cam help | 355s10 | Engine | 7 | 03-16-2008 05:34 PM |
| ZZ4 Camshaft experiences...My stock cam V/S ZZ4 Cam | Calderone | Engine | 7 | 01-25-2008 07:53 PM |
| Help Me Pick A Cam | Canadian Charlie | Engine | 2 | 11-16-2005 01:11 PM |
| Roller Cam Help!!! | Vsanthos | Engine | 13 | 10-31-2002 04:29 PM |
