Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ZZ4 camshaft
Thread: ZZ4 camshaft
  #18 (permalink)
Old 10-13-2012, 10:27 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
The special 305HO th2004r converter bolts right in a th700r4 (late 30spline)
Its a bolt in. If you can find it.
None of these cams work with a low stall and no gears on a 305.
The Lt1 and Lt4 had 10:1 and 10.4:1 compression
Find the cam from a 96 -2000 L31 5-7l vortec motor
96 to 2000 5.7liter truck motor and bolt it in.
Also used in the 383HT and 350 Ramjet crate motors.
High lift fast rate of lift short duration a improvement on the cam you got.
good torque in a 305.
factory cam specs
Part Number Type DUR @ .050" Lift C/R LSA Usage
14093643 Hyd. Roller 202/206 .403"/.415" 8.5:1 115 '87 350 Corvette and IROC Camaro
10134334 Hyd. Roller 235/235 .480"/.480" 9.0:1 114 350 ZZZ through ZZ2 crate motors
10185071 Hyd. Roller 208/221 .474"/.474" 9.8:1 112 350/345 ZZ3 & ZZ4 crate motor
10224241 Hyd. Roller - - - - '92 to'94 Gen. 11 LT1 350
10243779 Hyd. Roller - - - - '94 to '96 Gen. II L99 265 V-8
12370845 Hyd. Roller 214/224 .488"/.509" - 112 Off-road use, lobe for mech. fuel pump
12370846 Hyd. Roller 222/230 .509"/.528" - 112 Off-road use, lobe for mech. fuel pump
12370847 Hyd. Roller 232/242 .539"/.558" - 112 Off-road use, lobe for mech. fuel pump
125517051 Hyd. Roller 201/208 .447"/.459" 10.4:1 112 '95 to '96 Gen. 11 LT1 350, w/center dowel pin
12551142 Hyd. Roller 203/210 .476"/.480" 10.8:1 115.5 '96 350 LT4 w/1.6:1 roller rockers
24502586 Hyd. Roller 218/228 .525"/.525" 10.8:1 - '96 LT4 H.O.T crate motor cam, use
- - - - - - w/1.6:1 roller rockers.
N/A Hyd. Roller 202/210 .472"/.478" 10.0:1 11 '97 Gen. III LS1 Corvette 350, uses 1.7
- - - - - - roller rockers and Gen. III
- - - - - - tapered valve spring
24502476 Hyd. 212/220 .435"/.460" 9.1:1 112.5 350/300 CC crate motor
14088843 Hyd. 202/206 .403"/.415" 8.5:1 115 '83 to'86 305HO
12364050
3863151 Hyd. 221/221 .447"/.447" 11.0:1 114 327/350HP L-79
12364051
3896929 Hyd. 195/202 .390"/.410" 8.0:1 112 327/300HP
3896962 Hyd. 222/222 .450"/.460" 8.5:1 114 350 L-46, L-82
12353915 Hyd. 194/204 .401"/.423" 8.0:1 104 GM/Crane street
12353914 Hyd. 180/194 .378"/.401" 8.0:1 - GM/Crane very high, low-speed torque
12353923 Hyd. 224/234 .465"/.448" 9.5:1 114 GM/Crane off-road
12353918 Hyd. 214/224 .442"/.465" 8.75:1 112 GM/Crane marine & off-road
12353917 Hyd. 204/214 .420"/.442" 9.0:1 112 GM/Crane non-emissions vehicles & off-road
12353916 Hyd. 204/214 .423"/.446" 8.5:1 110 GM/Crane 50 state legal 305-350
12364052
3849346 Mech. 254/254 .485"/.485" 11.0:1 114 327/365HP & Z-28 302
12364053
3927140 Mech. 257/269 .493"/.512" 12.0:1 112 Off-road
12364054
3972178
3972182 Mech. 242/254 .459"/.485" 11.0:1 116 '70 LT1 360 to 370HP
" " " " 9.0:1 116 71 LT1 330HP
3965724 Mech. 262/273 .488"/.509" 12.5:1 112 2nd design, short track, road race
Key to table:
DUR = Duration, C/R = Compression ratio of engine used in (stock), LSA = Lobe Separation Angle.
